โJul-28-2013 06:09 PM
โAug-01-2013 04:24 PM
โAug-01-2013 11:15 AM
โAug-01-2013 09:35 AM
โJul-31-2013 06:59 AM
โJul-30-2013 07:23 PM
โJul-29-2013 09:17 PM
โJul-29-2013 05:54 PM
dalmationlovers wrote:
Open the drivers door and look on the sticker for GVWR. Take that number and subtract about 500 lbs for your DW and any gear you might put in the bed. Then go look for a TT that is 500 lbs or so under your GVWR that you can tow. Don't look at dry weight. If you have a tow package you should be around 7-8k in towing ability. If you are not sure check with your manual.
โJul-28-2013 07:46 PM
โJul-28-2013 07:21 PM
โJul-28-2013 06:26 PM
