? Memory Foam Mattress Question
dcmac214
What, if any, effect does an electric blanket have on memory foam mattress? Any damage or accelerated brakdown?
These 'cooler' nights DW & I like to turn the electric blanket on on our old lumpy spring mattress, feels sooo good getting into a pre-warmed bed. Got to replace it, thinking memory foam might be better for us in our old age than another spring mattress.
7 REPLIES 7
wwfloyd
When I bought a Tempurpedic memory foam mattress (years ago), it said not to use an electric blanket. I think it even said such use would void the warranty (as if they would find out; as if a mattress mfgr. would honor a warranty in the first place).
I did use an electric blanket, and I still do, with no-name memory foam that I now use. The heat does make them compress more. I sleep better in the summer -- with no electric blanket -- than I do in the winter.
hogcard
The only issue is that memory will get softer as it warms up. It will get really soft if you apply more than body heat. But you may be ok with that.
rav
use one in the house all winter and no issues- have been doing this for 3 years now.
fcooper
We're using a heated mattress pad on a memory foam mattress with no problems.
Fred
Fred & Vicki
St. Augustine, Florida
Winnetheygo
Hasn't been an issue for me. They seem pretty durable.
2oldman
Anything would be better than a spring mattress.
coolmom42
I used one with my memory foam mattress for a couple of years. (Until the blanket died.) I didn't see any issues.
You will have low heat from the blanket, and a couple of layers of sheets between the blanket and the memory foam.
Single empty-nester in Middle TN, sometimes with a friend or grandchild on board
