Apr-26-2014 07:05 AM
Apr-26-2014 07:29 PM
The water coming out the hose inlet accounts for the "no pressure" .. there is valve in there operated by a springy thing which is stuck open - you might get lucky and reset with small screwdriver or even attaching hose and turning on water for second or two .. not expensive or difficult to replace.
Apr-26-2014 04:52 PM
Apr-26-2014 04:07 PM
Old-Biscuit wrote:This would depend on brand & model of RV, my Forester will Not overflow like that as it has an overflow tube that exits to the outside, next to the tank fill.
Sounds like you are connected to city water source via a hose.......
The pump internal check valve is leaking allowing water from city water source to backflow thru pump into your fresh water tank.......overfilling it and it overflowed.
That is where your 'leak' has come from
The lack of water pressure....
That is because the internal check valve in the city water connection has jammed and is not allowing water in anymore....it did but now is stuck/failed.
Apr-26-2014 02:23 PM
Apr-26-2014 01:53 PM
Apr-26-2014 10:46 AM
Apr-26-2014 07:21 AM
