Packets or Liquid for Black water tank
Rainier
Folks,
I'd love to hear a conversation of packets vs liquid for black holding tank deodorizer. I have always dumped little bottles of the stuff and am fairly happy, but I like the idea of throwing a packet down the toilet instead because it seems less messy and more convenient. However, I want works best. Does anyone have any opinions on this matter. There are too many options out there! ๐Ÿ™‚
Thanks, Matt
47 REPLIES 47
letscamp12
Both packets and liquids have their pros and cons. Packets are definitely more convenient and less messyโ€”just toss one in and youโ€™re done. Liquids can be more customizable if you need to adjust the amount based on tank size.
If youโ€™re happy with the liquid youโ€™ve been using, itโ€™s probably working well for you. But if you want something easier to use, packets could be a great switch. It might be worth trying a few different options to see what you like best!
Not sure if you're aware but you are responding to a post that's 10 years old.
I appreciate new responses to old threads being new to full time trailer living
the only issue is you have to temper the information in that old thread.  so much has changed, been proven not a good way to do thing, or the opposit and it is a good way.  to me the best way to find info, is to search a topic, read all the old threads then post a new topic of discussion.  this engages people that are active on the board and can get you the most uptodate information.
a good example of this is older posts on LiFePO4 batteries..  no one knew exactly what they were or how they worked so we had a lot of myths and downright falsehoods that were being spread about them due to people asuming they were the same as other Li chemistry batteries, which took years to dispell.  if you dig up old threads then that puts that thread up front for new people like your self to ready and if you don't know anything about LiFePO4 your going to go away thinking your rv is going to burn down and so on..  personaly I would like to see any thread that has been inactive for 2 years be locked to read only.  plus the fact that new topics engage more people and more board activity.
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumber Queen WS100
DrTanTodd
We use the "toilet bomb" packets! They are easy to pack and no risk of tipping over and spilling.
Todd and Dawn
Maddy and Nugget the Cats
2014 Dodge Ram 2500 Diesel
2015 Jayco Pinnacle 31 RETS
DE88ROX
Just water here. After my trip to the dump station, I drop in a dishwasher packet that I brought from home and add a few gallons of water. figured all the sloshing around on the trip back will clean it real good. And, from what I read on here, the soap helps coat the tank so nothing sticks.
Part of my winterizing detail is cleaning the black tank. I rinse and rinse and rinse until nothing but clear liquid is coming out.
[COLOR=]TV- 2010 GMC Sierra Z71 EXT. cab
TT- 2012 Starcraft Autumn Ridge235fb
I think your thinking of washign soda, way different than soap.  soap will actualy make the walls sticky and attract things, washing soda is what makes it slipery and stopps stuff from sticking.
2016 Cougar 330RBK
The dishwasher soap will coat your sensors and you wonโ€™t be able to tell how much is in the tank
me to damnit haha.. saw you posted and didnt read what you said lol.
2016 Cougar 330RBK
kmbelt
I used to use the junky Thetford and Camco blue stuff, but have recently found this newer stuff that is fantastic.
Pure Power blue
this stuff is eco friendly and is safe for dumping in septic tanks.
2014 Ram 2500, 6.4 Hemi, CC, 4x4
2010 Puma 259RBSS
Tvov
Or... if you have the bathroom vent fan running when you flush. Try to remember to shut off the vent fan while flushing, turn back on when done.
_________________________________________________________
2021 F150 2.7
2004 21' Forest River Surveyor
beemerphile1
gbm97 wrote:
...Seems to me the rv stink pipes are not long enough to create a proper draft....
There cannot be a draft when there is only one opening. Where does the air enter at in order to be able to vent out the top? The vent stack is there to equalize pressure, not to eliminate smell.
If a system is operating correctly the only time for potential odors is the few brief seconds the toilet is being flushed.
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
my440
Ok about the smell. The smell that no such additive will completely rid the rising odors.
Seems to me the rv stink pipes are not long enough to create a proper draft. Rather than the stinky air rising upwards it lingers in the pit rising up through the bowl.
I have thoughts of a telescopic stink pipe, a whirly bird vent even a
solar powered inline pusher fan.
Any ideas? ๐Ÿ™‚
