โJan-02-2014 03:15 PM
โJan-07-2014 12:07 PM
dodge guy wrote:And your proof? If it is 44F and the wind is 30 mph, the wind chill is 30 degrees, but water will not freeze.ReadyToGo wrote:
Wind chill does not affect hoses, pipes, etc at all. Myth.
That`s what they say, but I can and have proven otherwise!
โJan-07-2014 07:19 AM
โJan-07-2014 03:27 AM
โJan-07-2014 03:16 AM
โJan-06-2014 05:25 PM
โJan-05-2014 05:32 AM
โJan-04-2014 06:01 AM
โJan-04-2014 03:09 AM
โJan-04-2014 01:06 AM
wa8yxm wrote:Good advice!
If it is a small trailer with all the water INSIDE the rig. Just put a small heater, even a 150 watt may well be enough to prevent freezing at 27. but a standard ceramic on low (900 watts) should work well, DO take care about keeping it away from things that flame on when heated. (Like wood or cloth or paper)
if there are exposed pipes in the "Wet" (Contining liquid) state, a infra red heat lamp perhaps 3-6 feet from the pipes (use a spot light style and put it far enough to light up all the pipes that need it) these are usually also in the 150 watt range.
I am expecting TEENS next week.. Not sure I have enough heat. but sure gonna try, LIkely will have to burn propane to keep it all thawed.
โJan-03-2014 08:40 AM
โJan-03-2014 06:49 AM
โJan-03-2014 05:53 AM
โJan-03-2014 04:35 AM
dodge guy wrote:
OH NO! a low of 30deg?!!! whatever shall we do!! BTW this morning it is -10 here in the Chicago suburbs (Monday is looking at a high of -10!!!!!!)
โJan-03-2014 04:22 AM
