refrigerator not working
lamoz
bought a 86 pace arrow and it came with a newer refrigerator a Dometic Rm2820 that was installed in Dec.2006 by Camping World for $1400bucks!! wow i did not know they were so expensive.
I can't seem to get it work, I've plugged the rv to shore power and have left for over a day and did not cool at all, I've also tried it with propane for over a day and still not working. Lights inside the fridge work, i have new house batteries and also checked the back for a flame and that is working.. I don't know what else to check for .
Any suggestions?
22 REPLIES 22
dbbls
If the stack gets hot the unit may not be level enough. It has to reasonably level for it to work.
2011 F-350 CC Lariat 4X4 Dually Diesel
2012 Big Country 3450TS 5th Wheel
lamoz
stack does get hot and nothing blocking it. Is the cooling unit replaceable? what does it look like?
Old-Biscuit
lamoz wrote:
Old-Biscuit wrote:
Do you have lights on the upper control panel?
Does the ON light come on?
Does the auto light come on?
Does the gas light come on with auto turned off?
Can you change temp setting(s) 1-5?
Check that you have 110V AC power to fridge
Check that you have 12V DC power to fridge
Check the two fuses on lower board (access from outside compartment).
One is for 110V AC heater (5A) and the other is for 12V DC Controls (3A)
Fridge is 'level'
Fridge is 7 yrs. old.......any powdery residue in outside compartment area?
yes to all, and NO powdery residue in outside compartment or any weird smells
regarding the fridge level, rv is parked on the street is not leveled but it isn't leaning too much either
Then it sounds like nothing is flowing in cooling unit.....plugged/blockage.
Gas lights, left on overnight and freezer isn't cooling down......(OR electric). When ON is the burner stack getting hot?
Nothing blocking air flow thru lower vent and out the top?
Burner working, electric working, controls working.......no cooling......bad cooling unit.
Don't know how non-level it is in the street but might try leveling rig and wait overnight.
Unfortunately......operating fridge off level causes blockage...a little at a time so the damage is accumulative.
lamoz
Fridge is 'level'
Old-Biscuit
Fridge is 'level'
bukhrn
Do you have the battery disconnect on, you need 12v to power the control board., check your fuses.
2007 Forester 2941DS
2014 Ford Focus
Zamboni, Long Haired Mini Dachshund
lamoz
do you have a link? looked but did not find it
midnightsadie
theres a trouble shooting site on here start there.
