โApr-06-2019 02:56 PM
โApr-09-2019 08:53 AM
โApr-08-2019 06:09 AM
ken56 wrote:
My wife is a member of the big wad club. There has been a few times where it caused a clog and would not drain completely, so that turns into a lengthly fill and try to drain again as many times it takes to break the clog loose. I have managed to get her to use somewhat less paper and have had no other clog issues. That said, we use our regular tissue we use at home, Sam's club brand.
โApr-08-2019 03:54 AM
gbopp wrote:Try eating some of that Kashi cereal for breakfast - you will be amazed at how much less TP is needed.Old-Biscuit wrote:
I like my 2 ply thick fluffy Charmin and a big wad of it.
Way too much information...:B
โApr-07-2019 09:08 AM
edatlanta wrote:toedtoes wrote:
Just don't use Northern. It's the only brand I've found that causes blockage. Everything else works fine.
I have been using Northern for 9 years full time. Never a problem. Just use a lot of water regardless of what you use.
โApr-07-2019 09:05 AM
โApr-07-2019 08:54 AM
โApr-07-2019 08:46 AM
Bobbo wrote:
It's a HOLDING TANK, for Pete's sake. Does the "solid waste" break down? No. It sits there until it is dumped. The same goes for TP. Who cares about it breaking down? When you dump your tanks, the TP will get dumped whether it is "broken down" or not. If you are nervous, get a tank rinser.
โApr-07-2019 07:28 AM
โApr-07-2019 06:03 AM
โApr-07-2019 06:01 AM
Old-Biscuit wrote:
IF it has 'RV' on the label it is overpriced, thin and useless
I don't process waste/TP....just 'hold' it until time to dump
Whether it has dissolved or not doesn't matter
Dump line is 3" header and the the weight/volume of liquids is more then enough to carry the 'stuff' down and out...WHOOSH!
Why too much OCD about waste tanks, TP ------GO Camping !
โApr-07-2019 05:33 AM
X2
Bill
โApr-07-2019 05:05 AM
โApr-07-2019 04:10 AM
โApr-06-2019 08:48 PM
