Feb-19-2016 11:44 AM
Feb-24-2016 05:58 AM
Feb-24-2016 05:40 AM
Feb-23-2016 07:25 PM
Reese Dual Cam Straight Line HP Sway Control
Feb-23-2016 06:55 PM
Feb-23-2016 06:26 PM
Gene&Ginny wrote:
Is it the V10 engine? If so, rv.net member Jbarca has experience with changing the plugs and posted an excellent series of pictures of his experience, not sure where he posted or how long ago. Seems those plugs tend to break off when trying to remove them and getting the remaining stub out of the head is not for the weak at heart. He is also familiar with the plug blowout problem.
Feb-23-2016 06:12 PM
Feb-23-2016 05:59 PM
Grit dog wrote:Fla904 wrote:
Also, it runs fine at high speeds but shuts down when I slow down or stop. I have maintained this thing meticulously. I don't know what this could be?
Didn't you just buy this thing like last month? Your meticulous oil changes while criss crossing the country back n forth for whatever reason (We know you're not running drugs or your cop hassle story would have never been posted, lol) have little to do with how an 18 year old ill kept RV will run.
You need to separate the problems its having to diagnose and better describe what the symptoms are. But since you threw out that there appeared to be no power to the starter one minute and then it cranked fine the next, likely means shorted/corroded battery cables or grounds somewhere on the vehicle as about 10 people have said now.
Feb-23-2016 07:37 AM
Feb-22-2016 05:29 PM
Feb-22-2016 11:38 AM
Fla904 wrote:
When it did shut off and I tried to re start it, it just clicked a bunch and never turned over and then all a sudden it started. No issues since.
Feb-21-2016 07:48 PM
Fla904 wrote:
So the problem has not came about again.. Should I still take it to the mechanic? I feel like they won't know what the problem is as there's a multitude of things that could have caused it.. Battery's are fine (there's three new interstates in it). When it did shut off and I tried to re start it, it just clicked a bunch and never turned over and then all a sudden it started. No issues since.
Feb-21-2016 07:21 PM
Feb-21-2016 07:04 PM
Feb-20-2016 05:29 PM
Feb-20-2016 03:49 PM
JaxDad wrote:How would he be able to restart the engine if the chassis battery had failed?
Sounds more like a dead chassis battery.
At highway speed the alternator is putting our power to run everything. But when you come to a stop the alternator is barely putting out a trickle I'm not keeping up with demand. Hilow things like the HVAC fan headlights brake lights and running lights eat up power.
At highway speed the alternator is putting out power to run everything. But when you come to a stop the alternator is barely putting out a trickle I'm not keeping up with demand. Hilow things like the HVAC fan headlights brake lights and running lights eat up power.
Get the chassis battery load tested ASAP
