What's the significance of the colors of nuts
thehippie
In the picture there's a 'silver' colored nut and the 'bronze' colored nut? Is there any meaning to the color? Does it mean that one nut is stronger than the other? Is there any kind of color coding of the nut.
It could mean nothing but newbie like me wanna ask, especially this involves WD hitch towing 7,000 lbs of trailer.
17 REPLIES 17
Ozlander
I don't see an unplated nut in the picture.
The one on the end has probably been in the sun more and is faded.
Ozlander
06 Yukon XL
2001 Trail-Lite 7253
myredracer
One is "gold" cad (cadmium) plated and one is "silver" cad plated. No difference. Info here: Cadmium.org
The plating thickness is extremely thin and both colors rust just as easily. Many steel parts are cad plated and it's not just used on fasteners.
We've got fasteners and other things cad plated under our TT and they are all rusting in just a year because our TT was exposed to lots of salt in the winter while being delivered to the west coast.
Cad plating is being phased out due to environmental concerns. Of course, not an issue for China. Not sure what they are using here in place of cadmium.
pira114
wa8yxm wrote:
This thread reminds me of a call to Tech Support at a company I know.. We need to replace a screw in our unit. We found the same size/rating screw at the hardware store but it is sliver not blue.
Customer Support response: The original screw was silver too before we painted it.
I don't know why, but that made me laugh pretty hard.
Fulltimer50
Bolts
For everything you ever wanted to know about bolts.
George
2011 F350 PSD CC LB 4X4 DRW Lariate
2015 Mobile Suites 41RSSB4 5th Wheel
wa8yxm
DougE
The big box stores typically have grade 8 hardware plated the bronze color. While silver colored nuts can be standard or grade 5, the grade 5 fasteners are typically fine thread.
Currently Between RVs
Bipeflier
No one in the US plates with cadmium anymore due to EPA, unless it is for a very specific reason.
The silver nut is zinc plated steel while the bronze colored one is zinc plated steel with an iridite chrome coating which further enhances the corrosion resistance. Most automotive fasteners use this process.
Unless there are markings on the face of the nut indicating a grade 5 nut, it is a grade 2.
2010 Cruiser CF30SK Patriot
2016 3500 Duramax
1950 Right Hand Seat GPS (she tells me where to go)
mowermech
The "silver colored" nut might be zinc plated.
The "bronze colored" nut might be cadmium plated.
Then again, the silver colored nut may be grade 2 or 5, and the bronze colored nut may be grade 8.
Black anodized nuts are usually grade 2 or 5.
It all depends on the manufacturer.
CM1, USN (RET)
2017 Jayco TT
pitch
The silver is an uncoated steel the gold is cadmium plated. There is no difference. What is the application? You need to use a nut that is equal in properties with the bolt or stud.
In other words do nut use a 2 or a 5 on a grade 8 bolt. Do not use aluminum on steel or vice versa.
Is this a shear application or a compression application. It all makes a difference.
Perhaps if you describe what you need to accomplish you would get a better answer. RV.net does not charge per word! go ahead free your mind,expand and expound on he subject at hand
thehippie
westend wrote:
The colored nut has more alloy in it. It is formulated like that to prevent rust.
Does it matter if I use steel or its ok to use either one?
SCVJeff
Really trying to hold tounge on the question. What I want to say will get me sent to the corner...
Jeff - WA6EQU
'06 Itasca Meridian 34H, CAT C7/350
philh
color doesn't mean a dang thing
fla-gypsy
Old-Biscuit wrote:
GO answer questions to your 'dumping waste w/o hose' post and then maybe I'll clue you in on the 'nuts'
X2 we are waiting patiently for the rest of the story
Lynnmor
The plating determines the color. Look at the nuts at McMaster-Carr.
