1/2 Ton Limit
Gene_K_2
Current set-up
2018 F150 Screw 4x4 3.5EB (1907 lb payload).
Husky Centerline TS Hitch
Jayco 22FB (6000 GCWR).
No real stability issues.
I usually have 1500+ lb left for tongue weight (I'm solo). I've been looking at a GD 2250RK (7495 lb) as a replacement.
Thoughts on whether it should be any real issue towing with a half ton. I'm sure I'll be okay on tongue weight (15% would be 1125 lb) but I really don't know how much is to much with a half-ton.
29 REPLIES 29
mbopp
Sheesh, I'd have no issues running an Imagine 2600 and maybe a 2670 trailer with that truck, and I'm usually not a proponent of half-ton towing.
2019 F250 XLT Supercab
Just DW & me......
mkirsch
Nomad II
Nomad II
Why would anyone run with the gray AND the black AND the fresh tanks full at the same time?
valhalla360
Nomad III
Nomad III
You are well within your ratings even running at the full 7500GVWR.
Go for it.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
MitchF150
I wouldn't fret it much.. I've got an older 13 Eco Max Tow with #1920 payload sticker, but it's a lot heavier truck with #7700 GVWR and #4050 rear GAWR.
Towing a #7000 TT and I have not taken it over any scales, but it tows fine and no issues otherwise that would cause me to think it's not a good combo..
In the end, it's all about how you setup the hitch and how it's loaded and how it just tows for you in general.
I load my truck and trailer heavy and don't worry about it at all.
Good luck! Mitch
2013 F150 XLT 4x4 SuperCab Max Tow Egoboost 3.73 gears #7700 GVWR #1920 payload. 2019 Rockwood Mini Lite 2511S.
Sandia_Man
Weight wise no issues as you have plenty of margin, and length wise you kept it very manageable for your tow vehicle. One of the biggest issues facing half-ton trucks towing TTs is dealing with rigs over 30' in length, heading down the road at interstate speeds can prove challenging at times.
Have a great time enjoying your new GD, although I like Jayco products I have always thought highly of GD rigs. I heard good things about their customer service, and that RK floorplan looks like a winner for your situation. Overall, a good truck/TT match, towing comfort should be good.
Gene_K_2
As to exact numbers. I suspect the racing corner scales were more accurate. A CAT Scale is really intended more for 20,000 - 40,000 lb axle weights plus is only to the nearest 20 lb.
7000 GVWR
1907 Payload
3450 FAWR
3800 RAWR
CAT Weights
3020 lb FA
2080 lb RA
5100 lb Total
Racing Corner Scales
2980* lb FA
2060* lb RA
5040 lb Total
(I've forgotten exact corner weights but those are within a few pounds).
Mike134
Getting back to the title 1/2 ton limit. With your F150 and it's 1907 lb payload the F150 forum consensus would put it's limits at 30' and under with a top end of 8000lb GVRW. Some on the F150 forum have HDPP 150's and they successfully tow over 30' and a 9000 GVWR. At 15% tongue weight that 8000 would be 1200 so you've got plenty of payload left over.
2019 F150 4X4 1903 payload
2018 Adventurer 21RBS 7700 GVWR.
BenK
Which of the approx 14 versions of the F150 do you have ?
Best to know what your TV's specifications are. Key will be the GVWR, GAWR and its actual weights on each individual axle when fully loaded, ready to tow
-Ben Picture of my rig
1996 GMC SLT Suburban 3/4 ton K3500/7.4L/4:1/+150Kmiles orig owner...
1980 Chevy Silverado C10/long bed/"BUILT" 5.7L/3:73/1 ton helper springs/+329Kmiles, bought it from dad...
1998 Mazda B2500 (1/2 ton) pickup, 2nd owner...
Praise Dyno Brake equiped and all have "nose bleed" braking!
Previous trucks/offroaders: 40's Jeep restored in mid 60's / 69 DuneBuggy (approx +1K lb: VW pan/200hpCorvair: eng, cam, dual carb'w velocity stacks'n 18" runners, 4spd transaxle) made myself from ground up / 1970 Toyota FJ40 / 1973 K5 Blazer (2dr Tahoe, 1 ton axles front/rear, +255K miles when sold it)...
Sold the boat (looking for another): Trophy with twin 150's...
51 cylinders in household, what's yours?...
Sjm9911
That was always very common, especially in pop ups , not sure how it is with TT. The published weigjts were out of the factory, anything added at the dealer was extra weight. So everything was an add on. But it does list tanks adding up to 190 gallons, so black, greay and fresh, filling those at 8.3 gallons adds 1570 or so lbs. So it needs a high gvwr or you would not be able to use the tanks it has.
2012 kz spree 220 ks
2020 Silverado 2500
Equalizer ( because i have it)
Formerly a pup owner.
Gene_K_2
Mike134 wrote:
That trailer weights 5546 dry. As a solo camper you really going to put 2000lbs of **** into it?
To answer your question that GD 2250 weighing 6500-7000 lbs will not be an issue for your F150.
The typical trailers actually received by customers appear to be about 800 lb heavier with 200+ lb more tongue weight. Many owner's were having issues with exceeding GVWR which is why GD added 500 lb to GVWR. It appears that the published weight may not include the mandatory option packages.
Sjm9911
Lol, he might if he fills all the tankes, there huge.
2020 Silverado 2500
Lwiddis
Mike, OP says new TT weighs 7495. IMO you determine weight by max allowed.
Mike134
wing_zealot
You wonโ€™t have any problem with hp and that 10 sp transmission is a fantastic towing machine.
Lwiddis
Loaded and wet youโ€™ll be 8600+ pounds. Upper limit IMO. Wouldnโ€™t try it in my Silverado at 1712 pounds payload but you have more.
