โNov-13-2017 01:42 PM
โNov-15-2017 06:35 AM
DrewE wrote:Grit dog wrote:
I use windshield washer fluid. 1/2 the price of the cheap stuff and it works.
Boat ballast tanks/pumps and rv drains and tanks.
If youโre pumping it thru the water lines, Iโd not use it there.
If you're putting it through the supply lines, definitely do not use winter washer fluid. The antifreeze ingredient in it is usually methanol (i.e. wood alcohol), which is quite toxic.
โNov-15-2017 05:46 AM
loggenrock wrote:
I avoid the alcohol stuff. I prefer NOT to pump anything marked FLAMMABLE throughout the RV... Got enough other flammable stuff in there... ST
โNov-14-2017 12:20 PM
โNov-14-2017 12:05 PM
Dave H M wrote:
Mortimer, so if that stuff is silicone based why can't a person just smear some plumbers grease on it. Is what I do. :h
โNov-14-2017 11:22 AM
โNov-14-2017 11:00 AM
โNov-14-2017 09:09 AM
โNov-14-2017 09:01 AM
โNov-14-2017 07:43 AM
StephJohn2010 wrote:
I know this stuff shouldn't be hard, but for some reason this is one of those things that I'm having trouble with:
1) I heard somewhere (once) that you shouldn't use the pink stuff with alcohol in it ... is that true? Of coarse, I can only find stuff that has "ethyl alcohol" in it.
2) What brand do you use?
โNov-13-2017 07:55 PM
โNov-13-2017 07:22 PM
โNov-13-2017 04:38 PM
โNov-13-2017 04:29 PM
โNov-13-2017 04:25 PM
