โJan-21-2015 07:09 AM
โJan-21-2015 04:07 PM
ScottG wrote:If that is the case then please explain why my '04.5 has one.
That went away with the 03 updated body. Dodge said the SB wasn't needed because of the increased length and geometry of the new trucks rear springs.
โJan-21-2015 08:01 AM
AH64ID wrote:ScottG wrote:
Excellent info - I think I'll put one on for the upcoming season camping.
You won't be disappointed.
I added mine because I was feeling the trailer (1200-1300lbs TW) on slow speed off-camber corners, on winding forest service roads. After the install that feeling went away.
Now I haul 2 quads above the bed rail, with gas/water/wood/etc below the bed rails and still have the same TW. Rock solid on corners and I only use about 20-25psi in the airbags.
โJan-21-2015 07:55 AM
โJan-21-2015 07:52 AM
โJan-21-2015 07:40 AM
Exactly, a wider and longer spring and a stiffer frame made the bean counters think it wasn't needed.
I added a hellwig rear anti-sway bar to my 2005, which is the same suspension as your 2102 (I have upper overloads, but they are never engaged), and it has been an improvement empty and loaded. I have yet to find a situation where I don't like the swaybar.
While the truck was very stable without one, it's on rails with it.
โJan-21-2015 07:31 AM
โJan-21-2015 07:13 AM
