2012 and older Ford Escape's
bocanut50
This is a FYI if you own a Ford Escape. 2012 and older.
We had a 2011 Escape, Automatic. This applies to 2012 and older. 2013 and newer ARE NOT TOWABLE. They have a different transmission.
Our 5 months of hell.
We bought the Escape new in 2011. First trip out we lost the first transmission in NC at 1100 miles on the vehicle. All 4 down protocols were followed. Ford replaced the transmission within one week and provided a rental car. The repair dealership also provided also provided a Service Bulletin that the Selling dealership didn't,' even though they new ahead of time we were towing the car 4 down. That's when we found out about the transmission level. All other shifting rules and speeds were followed.
This year, also in NC, in July, the same thing happened. This time it took Ford 5 days to tell us they wouldn't have a transmission until Sept. We made a decision to Trailer the car back to PA and have it fixed here. So we waited until Sept, only to be told by FORD that it would be late in DEC. we MIGHT have a transmission. In late Oct, We told them that was unacceptable and we would be filing a Lemon Law Suit. Ford told us to wait the weekend and they would get back to us. Finally in Nov, Ford bought back the car and we are done with it.
Five months of hell. If your Escape works for you, GREAT, but you have been warned, due to supplier problems, there are NO Transmission's available. Escapes are a great vehicle to drive. Just not for RV Towing!!! YMMV
Bill Stiles
2003 Discovery 38T
2013 Ford Edge SEL
15 REPLIES 15
Silica
In reply comment that ford escape "post 2012" are not towable is contrary to the manual which states they are towable all four down so long as the transmission fluid is lowered to lowest mark. In fact, I just completed a 10,000 mile tour with no apparent problems. I did however extend my extend my warranty just in case after reading all the forum comments.
janstey58
Cant say it enough, for the 2012 Escapes, build date is the key. Debate all you want, but that is the correct answer.
Jeff and Kim
2015 Fleetwood Discovery 40E
Freightliner Chassis 380HP DP
2012 Ford Escape Limited Toad
bocanut50
Another point, if you buy an Escape, don't plan on a replacement trans any time soon. Ford has outsourced them, and they have NONE, anywhere. We were promised one 3 times, and that's when we threated them with a Lemon Law suit, that they settled with us!!
Bill Stiles
2003 Discovery 38T
2013 Ford Edge SEL
bocanut50
As a former Escape owner, I wish I had done my homework on Escapes, on this Forum. I never would have leased the Escape in the first place. I would have gone with a proven toad like a Honda, Toyota, Chevy product, etc.
The other point here is it doesn't matter what's in the Ford owners manual, they have 3 Technical Service Bulletin's on this vehicle. The last one says, "If you are going to tow four down we highly recommend you install the cooling pump". Buy the way, you have to buy it from FORD. That should tell you something!!!
JMHO YMMV
Bill Stiles
2003 Discovery 38T
2013 Ford Edge SEL
mowermech
amcconnell wrote:
After reading all these posts about flat towing a Ford Escape..... (some negative and some positive) I'm really confused. I am about to buy a 2011 Ford Escape 2 wheel drive with 4 cylinder engine with the intent of flat towing it behind my RV. The Ford owner's manual and also the Motorhome.com posting both say it can be flat towed if I start the engine every 6 hours. How do I know who to believe? I cannot afford to buy a new vehicle for towing and am stretching to buy a used 2011 model... so, I have to get this right the first time. Hoping to get some good guidance here.....
allan
Get a Jeep Wrangler 4X4 and you will have absolutely NO problems towing it. I prefer 2006 and earlier, but that's just me. They changed the body lines somewhat, and I don't like the looks of the newer ones. For best ride, you want one with coil springs.
CM1, USN (RET)
2017 Jayco TT
the_armadillo
Allan
If it were me, I would look for a different toad. When we were looking for a vehicle to flat tow, we rented several different vehicles so we could form our impression over a longer period than just a test drive. We found that we liked the Escape over the Jeep vehicles we tried due the ride comfort, visibility and road noise. So we went with a 2012 Ford Escape Hybrid which has a completely different drivetrain than the conventional Escape. The conventional Escape unfortunately has had a very checkered past with flat towing. Some have had very good luck while others have had complete misery which is not what you want to deal with while travelling. It seems that everytime Ford felt that they had it figured out, the transmission failures would continue. There were TSB's, Lube pumps, internal manufacturing mods, etc., but I believe there have been reports of failures with each of these changes and/or VIN ranges.
As a second owner, Ford will not be there to cover a future transmision for you. As such, I would recommend looking at something different than a conventional Ford Escape. Our Escape Hybrid toad is great and does not suffer from the same transmission issues. We have had great luck with all of our Ford vehicles and will continue to purchase them in the future but they failed in their design and support of the conventional Escape for RV towing. You may want to look at a used Escape Hybrid, C-Max or possibly some of the Jeep models.
jcsb
Had a 2011 Escape. Transmission fried on a return from Florida. Followed all the rules. had trans fluid lowered by dealer, went thru the gears and warmed up prior to towing. Stayed under 65, started and let run every couple of hours.
FOrd replaced with a newer model transmission. Ford rep who visited the dealer who replaced the trans, told them, Ford Lied.
Ford paid to have a lube pump installed later that year. but I did not have a warm and fuzzy feeling even after that.
Due to a house fire, trans fried again with the entire front end. Now have a CRV.
Jim Hunter
amcconnell
allan
janstey58
Jerseyjim, lowering the tranny fluid is a one time operation for the life of the Toad.
jscb apparently you didn't read my previous post about build dates. I just hate to see incorrect, blanket statements posted on these forums.
I still love my "proper build date" 2012 Escape Toad!
Jeff and Kim
jerseyjim
All that info....what you can/cannot do SHOULD be in the owners' manual. I know it's not the American thing to do...but reading it does help. Salesmen are interested in only ONE thing. Sell the car. Most likely there is no real training regarding ANY kind of special stuff...except for what is on the sales floor. Ands they, too could care less about "after the sale".
In my case, my 2011 Ranger 4WD was not towable until I put in their (Ford only = $400) "Transfer Case Neutral Kit". Now I tow that pickup witn no problems.
Ford seemingly has little interest in the 4-down towing thing....as evidenced by the very limited number of vehicles that can do it....however, GM, at least in 2011 has the most in the most price ranges.
Once more...i have to say, if you're going to tow 4-down....BUY A VEHICLE THAT CAN DO IT with little or no modifications. At least in my world, buying a motorhome is not an impluse buy...but something thought about for quite a long time....and y'gotta figure out what is needed to make one happy. A "toad" definately can be part of the equation. So...one must RESEARCH.
And what is this lowering the level of the transmission fluid? That mean you have to add the stuff back after reaching your destination? Add/lower/add/lower....holy smokes!
jcsb
janstey58
there are a lot of people who will disagree with you about that. They have had their transmissions bun up multiple times. Fortunately for us, our car burned up in a house fire. I will never trust Ford on towing 4 down. Even after having a lube pump put on, transmissions have fried. Take a look at prior posts and you will see continuing issues.
Apparently Ford did not learn from the Pinto.
Jim Hunter
mowermech
If someone GAVE me an Escape, I would sell it and buy beer and salted nuts.
Probably cashews.
CM1, USN (RET)
2017 Jayco TT
janstey58
No pump needed on the Escapes with the proper build dates.
Jeff and Kim
bocanut50
Do you have the Trans. Cooler Pump? Ford bought the rights for the Remco Pump for Escapes and now charges around $3500.00 plus labor. If I still had an Escape, I personally would not tow it without the pump. There has to be a reason Ford bought the rights from Remco.
JMHO YMMV
Bill Stiles
2003 Discovery 38T
2013 Ford Edge SEL
