2015 Ford Expedition - Largest TT I can pull SAFELY?
tama2112
Hi Everyone,
I am brand new to this forum and TT's. I've been doing some reading here and its all be very helpful. I'm not sure there is a topic specifically on the newer Expedition so wanted to post here. I am trading in for a 2015 Ford Expedition (not EL) w/ HD towing package. Specs:
4x4 3.5L V6 EcoBoost
GCWR: 15,200 lbs
Maximum Loaded Trailer Weight: 9,200 lbs
Payload Capacity: 1,650lbs
I do NOT want to push the limits of the Expedition. I have a family of 4 and want to get the largest that I can safely tow (both in weight and length.
Could I get your recommendations please?
Matthew
22 REPLIES 22
tama2112
Hi All,
I updated the original post to include the payload capacity.
The TT's I'm looking are the:
1) Dutchmen Aerolite 250KBHS. Its a 32' w/ shipping weight of 6,036 lbs. Dry hitch weight of 774 lbs.
2) Dutchmen Aerolite 242BHS; Its a 28.6' w/ shipping weight of 5,575 lbs. Dry hitch weight of 735 lbs.
What are your thoughts?
tama2112
braindead0 wrote:
tama2112 wrote:
I do NOT want to push the limits of the Expedition. I have a family of 4 and want to get the largest that I can safely tow (both in weight and length...
There is waay too much wishy washy in those two statements. I'd suggest you educated yourself on towing and how that relates to the various weight ratings on your vehicle.
There are people here who would find running at the limits of vehicle ratings as safe and acceptable, others not so much.
In the end you are the only one that can make that determination.
Hi - I don't the statement is very wishy washy. I want to get as big as possible without pushing the limits of the Expedition. I don't want to get a 20 ft trailer if the Expedition can easily tow a 28 ft. I'm basically looking for a recommendation on length and weight where fully loaded I can tow to the beach and though the mountains.
I went to a dealer today, and the salesman said verbatim "if you can tow 9,200, then just make sure you keep everything under 8,200". I don't think that is accurate... I can't rely on a salesperson to give me information about keeping my family safe on the road..
tama2112
bikendan wrote:
tama2112 wrote:
you're leaving out the most important spec, PAYLOAD capacity from the yellow sticker on the driver's door.
ESPECIALLY important on SUVs, since they usually have lower payloads compared to their towing capacity.
you'll run out of payload capacity WAY before you get close to the max towing capacity.
Good point! I updated the details to show payload capacity of 1,650 lbs.
Lynnmor
You did mention length. I wouldn't want anything longer than 24' nominal length, about 27' overall. JMHO.
mbutts
As a former Expy owner, I would suggest keeping below 6,000 gross (not dry) weight for shopping. Once you find a trailer you like, you can weigh your Expy loaded with people & stuff to determinensure your available payload.
Mike Butts
DW+DD+DS+Poodles
2017 Forest River Forester 3011DS (first MH!)
Previously 1999 Coleman Santa Fe pop-up, 2007 Kodiak 23SS hybrid, 2013 Sunset Trail 29SS travel trailer
braindead0
2015 RAM 1500 4x4 5.7, 3.93
2013 Econ 16RB TT
BenK
tama2112 wrote:
Hi Everyone,
GCWR: 15,200 lbs
Load up the TV with everything as if going to tow. Everything as in
people, pets, luggage, toolbox, etc and weigh it
Then take that actual weight, add WD Hitch weight and the trailer
tongue weight. Then subtract it from your GCWR. That will then
provide the actual MTWR (max tow weight rating) of the actual weight
for the trailer
NOT the 'dry' weight of any trailer, but the ACTUAL weight of the
trailer...if you do not have the trailer, then use the trailer's
GVWR that you are looking at. That is the maximum weight that the
trailer OEM says it can hold
Matthew
But...that will NOT have the tongue weight in your calculations above.
Again, you need the actual weight of that tongue to figure and again
if you do not have the trailer yet...use the brochure tongue weight
of that 'dry' weight trailer
That will provide the percentage range the tongue weight vs the dry
weight of the trailer...then using the trailer GVWR...use the same
percentage to give you the number needed to figure the above
In the end...there is only one person responsible for the setup and
that is the driver...none of the advisors here has any skin in that
game...
-Ben Picture of my rig
1996 GMC SLT Suburban 3/4 ton K3500/7.4L/4:1/+150Kmiles orig owner...
1980 Chevy Silverado C10/long bed/"BUILT" 5.7L/3:73/1 ton helper springs/+329Kmiles, bought it from dad...
1998 Mazda B2500 (1/2 ton) pickup, 2nd owner...
Praise Dyno Brake equiped and all have "nose bleed" braking!
Previous trucks/offroaders: 40's Jeep restored in mid 60's / 69 DuneBuggy (approx +1K lb: VW pan/200hpCorvair: eng, cam, dual carb'w velocity stacks'n 18" runners, 4spd transaxle) made myself from ground up / 1970 Toyota FJ40 / 1973 K5 Blazer (2dr Tahoe, 1 ton axles front/rear, +255K miles when sold it)...
Sold the boat (looking for another): Trophy with twin 150's...
51 cylinders in household, what's yours?...
bikendan
tama2112 wrote:
Hi Everyone,
GCWR: 15,200 lbs
Matthew
