โSep-12-2021 10:55 AM
โOct-06-2021 05:45 AM
โOct-06-2021 05:17 AM
โOct-06-2021 05:00 AM
โOct-05-2021 08:04 AM
dodge guy wrote:I looked at blue ox and the base plate all bolt on the same Before i towed the Ford Focus i towed a Honda for years . I sold my Honda and the guy i sold it to is still towing it with no problem . I was going to buy a new Honda CRV in 2015 . I found out you can no longer tow them because of the new tranmission. So i had to settle for a Ford Focus . Big mistake after 4 transmission 2 modules and unibody problems . It looks like the base plate manufacture and car manufacture need to get together to engineer the right product especially for unibody cars.
Blue ox gives you the same safety cables to go around the frame rails. Must be something with the Focus, because I havenโt seen those on other vehicles including my Explorer.
โOct-04-2021 05:55 PM
โOct-04-2021 03:36 PM
j wackerly wrote:hohenwald48 wrote:The reason i posted this post was to make aware this could happen to anybody that tow a Ford Focus . I purchased this car because Ford said it can be flat towed as stated on page 185 of owners manual. And roarmaster base plate will work on this car per instructions . As a consumer who can you believe ? The only way this could be avoided is to have a full frame car .
Like I said, Ford designed the chassis and specified the welds to hold the body panels, doors, bumpers and other components, in place under normal use. The owner, in conjunction with the baseplate installer and manufacturer endeavored to modify the vehicle to serve a function not considered by the Ford design engineers. Any failure of a vehicle caused by an unauthorized modification is the responsibility of the person making the modification. Ford has no control over how you decided to mount the tow bar. :R
According to your logic, if I decided to mount a 5th wheel hitch on the roof of a Camry and pull a 40' 5th wheel around, Toyota should be responsible if the roof couldn't handle the stress
As to the transmission, based on post #1 I thought this was a thread about a tow bar failure.
โOct-04-2021 12:06 PM
โOct-04-2021 10:05 AM
โSep-30-2021 03:41 PM
โSep-30-2021 02:31 PM
โSep-30-2021 02:20 PM
โSep-29-2021 10:42 AM
โSep-29-2021 09:41 AM
dodge guy wrote:
My buddy had his replaced at 30k miles. and has been flawless for 100k miles. just a month ago he needed to have the shift module replaced. still under the extended trans warranty. all these transmissions are, are a manual transmission with a complex shift assembly attached to them.
โSep-29-2021 08:30 AM
j wackerly wrote:hohenwald48 wrote:How about the transmission problems 4 in less then 5yr . I am not the only one on that .
Actually, I think fault lies with the baseplate manufacturer, the installer or with the vehicle owner. They're the ones who designed and installed a baseplate to an insufficiently strong point on the vehicle frame. Like someone said, if the baseplate manufacturer designed the baseplate to bolt to the license plate bracket, who's fault would it be when the license plate bracket pulled off?
Several years ago some baseplate manufacturer (don't remember who) designed a baseplate for a Wrangler that bolted on to the lower front air dam bracket. Several folks had issues with that but it certainly wasn't Jeeps fault.
When you bolt something on to a vehicle, it's your responsibility to make sure it's bolted to something that can handle the load. Ford did nothing wrong here. They designed a frame to hold on the front panels of a car they built. I doubt they ever certified the baseplate design. They did say the car could be towed 4 down but they likely never said you could bolt a towbar in that location.
And Ford doesn't make the decision as to who can bring a class action lawsuit. :S
โSep-29-2021 06:24 AM
