50 amp to 30 amp
rvnutts
This is our first fiver with 50 amp. We will be staying in a 30 amp site. We have an adapter. I know we can only run one air conditioner at a time. Is there anything else I need to know?
Brian and Lynn
2017 Ram 2500 SLT 6.7L
2013 Heartland Big Country 3250ts
25 REPLIES 25
jplante4
Correct. My Xantrex will bulk charge the batts at 125 amps DC if I let it. I normally leave the controller set to 30 amp service so it doesn't drag the genny down so far as to get the Progressive to kick off. In that mode, the Xantrex will shed loads to keep the load under the setting. What load does it shed? The charger.
Jerry & Jeanne
1996 Safari Sahara 3530 - 'White Tiger'
CAT 3126/Allison 6 speed/Magnum Chassis
2014 Equinox AWD / Blue Ox
Bobbo
Cummins12V98 wrote:
MrWizard wrote:
Cummins12V98 wrote:
WH and Frig on GAS you CAN run Both AC's on 30A.
With Batteries Fully Charged
What do the batteries have to do with it?
With the batteries depleted, the converter/charger (or inverter/charger if that is what you have) pulls a SIGNIFICANT amount of energy in the attempt to recharge the batteries. I have a 55 amp converter/charger. That is 55 amps of 12v power. To get that you have to pull about 6 amps of 120v AC power. If you are on a 30 amp outlet, that is 20% of the power available. Not insignificant.
Bobbo and Lin
Cummins12V98
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
MrWizard
Moderator
Moderator
I can explain it to you.
1997 F53 Bounder 36s
Braces
If you have the MicroAire Easy Start adaptors on both ACs you have a good chance that both will run on 30 Amp. Call Micro Aire and talk to their customer service reps.
Cummins12V98
rvnutts
Thanks all. I think I've got enough good advice to make it!
Brian and Lynn
jwandvassie
Second Chance wrote:
Boomerweps wrote:
50 amp connectors actually supply TWO 50 amp hot lines. Normally each leg gets split between to two busses (buss bar) that each supply their own circuits.
So you may have some outlets and items that won't have power. I expect that each of your ACs is on separate busses.
However, the dogbone adapters split the available 30 amps between the two legs in the RV. You shouldn't have any problems with outlets or appliances not working.
Rob
X2
time2roll
If running the air I would have the water and fridge set to propane only.
Same as your previous 30 amp RV.
TexasShadow
we usually pop our breaker because we forget to turn off the electric hot water heater and then try to make coffee, run the microwave, etc etc.
๐Ÿ™‚
TexasShadow
Holiday Rambler Endeavor LE/ 3126B Cat
Sometimes BMW K75 on Rear Carrier
Jeep Grand Cherokee or 2016 Ford XLT 4x4 super cab with 8 ft bed
M&G aux brake system
854 Watts of Solar Power
Always remember you're unique, just like everyone else.
doxiemom11
We have always been able to run 1 A/C and the refrigerator and water heater on electric. If we use the microwave or convection oven, then we shut one of the other thing off just so it doesn't try to kick on. We forget once in a while, but just reset the breaker and you are good to go. We also have a Progressive power manager.
MrWizard
Moderator
Moderator
your on 30amp
use this RV just like you did your 30 amp RV
(1) A/C, turn off A/C to use MW etc
just camp the way you did before
when you get the use of a 50amp site you can splurge and use more power, like both A/C units
wa8yxm
Fridge only draws about 300-400 watts so you can run it either way.
Water heater is 1200-1500 unless you do what I did and change the heat element
(I also had to put in a new tank but while I had it on the bench I pulled the 1500 watt 120 volt element and put in a 1500 watt 240 volt element. For a resistive circuit W=IE I=E/R so W=(E^2)/R so the element I use is 375 Watts.
I have yet to trip a 30 amp breaker since the mod. Both Fridge and WH on Electric. One A/C. I do cut it off for Microwaveing
RoyB
Like one of the post said - be sure to bring along a couple of 15/20A Extension cords and plug them into the 15A/20A Service receptacle at the site.... You can plug a few things into them by them self to help out... We do that all the time with our setup especially when we are running portable oil-filled space heaters etc...
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
