โApr-17-2018 06:02 AM
โApr-18-2018 01:38 AM
nal13 wrote:Ralph Cramden wrote:
Ya I have seen them towing a space shuttle and sled full of blocks up a burning spiral tower. You can probably tow a DRV LX455 with one.
Then I'll order one of those.
โApr-17-2018 10:44 PM
โApr-17-2018 09:09 PM
htss wrote:
Others have covered weight but I would be concerned about clearance to cab. I think some beds are only 5.5' and even on a 6.5' bed the clearance to the cab can get scary on sharp turns. Maybe you have the long bed and it is not an issue though.
โApr-17-2018 08:39 PM
โApr-17-2018 08:28 PM
Beaker wrote:
Can't make any comments about towing but $45,000???
โApr-17-2018 07:58 PM
โApr-17-2018 07:06 PM
kerrlakeRoo wrote:
Nor will you like the Titans Payload capacity. 1364 to 1950, and usually the diesels are the ones at the low end on the payload range due to the engines weight.
gmw photos wrote:
A new Titan XD will have a 4900 pound rear axle capacity. Either gas or diesel.
โApr-17-2018 07:02 PM
xtech wrote:
Do not go by your payload sticker.
MFL wrote:
Your Tundra RAWR of 4150 is pretty good for a half ton. If you keep your loaded pin weight within that number, you should be alright.
โApr-17-2018 06:50 PM
โApr-17-2018 04:07 PM
nal13 wrote:
I have been looking into the Nissan Titan with the cummins as a truck, but I don't think I want the cost of a diesel.
โApr-17-2018 11:51 AM
โApr-17-2018 11:15 AM
โApr-17-2018 11:07 AM
โApr-17-2018 10:08 AM
โApr-17-2018 09:50 AM
nal13 wrote:rhagfo wrote:
I have seen several Tundraโs towing 5erโs, none looked overloaded, sitting level, tires not flat on the bottom. Didnโt ask weights .
Ya, I have seen them hauling 5th wheels with boats on the back.
