8% grade descent
PatsRock
Newbie Here. F350 and 37' fifth wheel.
Yesterday I went down an 8 degree slope and left it in Tow Haul while using the breaks on trailer and truck to slow me down. I was thinking I might have been better off starting in 2nd gear at the top of the hill.
What is the correct strategy for braking on a big descent?
40 REPLIES 40
BurbMan
I would slow enough to drop into 2nd at the top of the hill, possible 1st depending on how twisty/turny. Leave it in tow/haul, that provides additional engine braking. I know on the burb 2nd gear limits speed to 45, 1st gear to about 30 on these steep grades. As long as no sharp curves I am OK at 45.
marcsbigfoot20b
Tow haul mode is a seperate map in the computer. This alternate map will have things like more line pressure, TCC lock up stays on with more load or throttle, stays in gear longer before upshifting and not downshifting with light throttle......in a nutshell.
With tuning software like EFI Live you can modify these settings like I have done on my truck, like adding TCC to second gear which was not available on the OEM mapping.
dave17352
Dwight45 wrote:
This is how it was explained to me. Decide at the top of the pass what speed you want to descend at, say 30mph. Pick a gear that will allow that speed. When you are about 10mph over that speed brake hard enough to return to 30mph, but do not brake for more than 5 - 7 seconds. Braking hard for a short period of time and then not using the brakes until the need to brake again results in cooler brakes. As someone said constant braking does not allow the brakes to cool. Emercency option, I lost my trailer brakes at the top of Monarch Pass in CO heading west. Couldn't get them fixed so I engaged 4L (4 wheel drive truck) and went down about 20mph. Only touched the brakes a couple of times but this is not something you want to do on dry pavement. I didn't have much choice.
Dwight
Then you are saying 1st gear in two wheel drive would not have held your speed down. I found in my Jamboree that first gear would hold that motor home back on very steep grades.
NOW 2017 Leprechaun 260ds
2005 Forrest River Cardinal 29rkle FW
1998 Lance 980 11'3" TC
2017 CHEVY 3500 SRW 6.0
B@W turnover ball @ companion Hitch
Honda eu3000 generator mounted on cargo rack
Crestliner 1850 Fish Ski boat mostly fishing now!
Dwight45
Dwight
dave17352
mkirsch wrote:
PatsRock wrote:
Thanks so much for the help!
If I want to start out in 2nd gear at the top of a hill do I have to put it in Neutral, disengage the tow/haul, then put it in second gear? Just wondering what the correct sequence is?
No, and why would you ever think that it worked in such a cockamaime fashion?
gosh, that wasn't very nice!:E
mkirsch
Nomad II
Nomad II
You slow down to where the engine won't over-rev when you drop it into 2nd, and drop it into 2nd. Tow-haul is neither here nor there in this situation because you've overridden the shifting system by dropping the truck into 2nd.
noteven
Edited - OP suggest you ask an experienced driver to go with you on some practice runs to show you how to control a vehicle on downgrades.
enblethen
There is normally truck warning signs for steep down grades. Follow those instructions.
Been over many high passes and there is signs warning of down grades, usually a pull off at the top with shoulders and some have areas to check your brakes. this is the point where you would shift transmission down.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
RoyF
Gdetrailer wrote:
enblethen wrote:
You should come to a near stop before descending. Then put the transmission in a lower gear. You may even need to be in low.
Rule of thumb in previous post is a good place to start.
Do not use the brakes them selves. You may not have any left at the bottom.
I have been on a lot of highways with 65mph-70mph speeds where "nearly stopping" will result in someone rearending you.. Not sure if you could really apply this to all roads, perhaps a very remote mountain road with no traffic..
A near stop is not needed for an 8% descent. Don't slam on the brakes, but gradually slow to 50 mph before the descent and put your flashers on. If you can't hold that speed with engine braking then brake until the transmission downshifts to a gear that will hold the speed. The thing is to never let the speed start to get away from you.
time2roll
Just pull the lever while rolling.
dave17352
trail-explorer wrote:
Often times I will manually activate the trailer brakes rather than continually using (and having the fear of overheating) the truck brakes.
I will use the truck brake pedal, but only occasionally and will alternate with manual activation of the trailer brakes.
THere's times where no matter how slow you start at the top, you will have to use the brakes some. I had this experience coming out of Beatty, NV in to Death valley, and the same thing leaving Death Vally going in to Panamint Valley.
This I disagree with. If you start out in first gear I don't believe you would have to use the brakes. But that is JMHO
Thom02099
In my Tahoe, I always use the tow/haul button. I also use 3rd gear rather than OD. When descending, I simply downshift to 2nd gear. No need to go into neutral. Have never had any problems. Only time I have to use the brakes is descending in canyons and coming up on severe curves. Lightly braking, and letting the engine/tranny do what they do best.
2007 GMC Sierra SLE 3500HD Dually
2016 Coachmen Catalina Legacy Edition 243RBS
2007 Keystone Outback 25RSS - R.I.P.
ReneeG
smkettner wrote:
Did you use the brakes firmly to get speed 10 to 20 mph under the limit then coast back up to speed?
Riding the brakes gently to maintain constant speed can lead to overheating.
X2. 2011 F350 DRW Diesel here with Tow/Haul mode. The best thing we've ever had for those steep descents.
2011 Bighorn 3055RL, 2011 F350 DRW 6.7L 4x4 Diesel Lariat and Hensley TrailerSaver BD3, 1992 Jeep ZJ and 1978 Coleman Concord Pop-Up for remote camping
Dave & Renee plus (Champ, Molly, Paris, Missy, and Maggie in spirit), Mica, Mabel, and Melton
PatsRock
trail-explorer
Bob
