โOct-18-2018 09:01 AM
โOct-19-2018 08:37 AM
โOct-19-2018 08:05 AM
mkirsch wrote:
Where do you get that it is a 12K toy hauler? Jayco Octane Super Lite 273, which is what this appears to be, GVWR is only 9950.
โOct-19-2018 07:04 AM
โOct-19-2018 07:03 AM
goducks10 wrote:
So you don't have the HDPP option. All you have is a Max Tow.
I'm guessing here, but it looks to me like you're probably over on the receiver rating and I never read where you mentioned whats in the truck.
P rated tires are not on the HDPP option. And your payload would be near 2300 lbs.
does you truck have the 5'.5" bed or 6'.5" bed.
I could be wrong but I thought the HDPP F150 came with LT tires.
I don't think you have enough truck for that heavy of a TT. The reason that it towed so much better with the lighter TT was because the TT was not as heavy as the truck.
You now have a long heavy TT behind a light weight truck with squirmy P rated tires and soft suspension.
TH have the axles farther towards the rear to accommodate for rear loading. Jayco specs the dry tongue weight at 1080 lbs. No propane, battery or anything else up front. Add 60lbs for propane, 100 batteries. You're at 1240 lbs with out anything else in the front.
Hard to tell how much the dirt bikes reduce the tongue weight since the axles aren't dead center in the equation.
โOct-19-2018 06:55 AM
mkirsch wrote:
Calm your roll, Larry.
Toy haulers tend to be super-heavy on the tongue from the factory because the back half is nothing but open space. This model is no exception with a dry tongue weight of 1080lbs, 17% tongue weight. Unless you are hauling lead ingots, what toys you've put in there should not bring the tongue weight down THAT much. It has a 3500+lb cargo capacity.
It's a heavy rig and a lot for that truck even with all the suspension upgrades. Probably closer to 9000 after you consider all the options. This is what I try to warn people about... It'll do it but you may not like it, then what?
โOct-19-2018 06:36 AM
โOct-19-2018 06:21 AM
โOct-19-2018 06:09 AM
LarryJM wrote:95jersey wrote:
Everyone is giving great advice! It looks like my truck as P tires, so next time I buy tires (spring), I will go LT. That should help and is a no brainier.
Regarding the hitch. It is a Curt Manufacturing Cur17022 Round Bar Weight Distribution Complete Kit 10,000 lb Towing/1,000 lb Tongue Weight.
The specs on Jayco trailer are 6,450lbs dry and the hitch weight is 990lbs. I pack fairly light as most trips are just long weekends. But we can account for 2-3 dirt bikes at 250lb each, a 125lb generator and 54 gallons of water (450lbs), and another 200lbs for kitchen stuff, 2 propane tanks and a battery. So rough estimate 8000lbs?
I will take pictures of the set up tomorrow as I am taking it in for winterization.
Also, I have no idea where to weight the set up, how do I locate a place to do this?
:E :E :E :E :E :E :E :E
A 12K+ GVWR TH behind a F150 with only a round bar 1K TW hitch makes me think you are not just a little, but a LOT over in more than one rating and some very safety related like tires. This makes my recommendation to NOT TOW THIS except to the nearest CAT scale to see where you are weight wise. Finally, PLEASE be VERY, VERY CAREFUL getting to the CAT scale since your rig could possibly be well past being safe on the road.
Larry
โOct-19-2018 05:56 AM
โOct-19-2018 05:47 AM
โOct-19-2018 05:04 AM
โOct-19-2018 04:31 AM
LarryJM wrote:Totally agree. Here is some help for you to do this: CAT Scale Locatordodge guy wrote:
You need to weigh it with the toys and all your stuff loaded ready to travel. I think youโll be surprised at the numbers you find, specifically the tongue weight. Iโm betting it will be low. Proper tongue weight will be 12% of the trailers loaded for travel weight. Without knowing for sure, Iโm guessing youโll be around 9k lbs trailer weight. You want at least 1200 lbs on the tongue.
Get it weighed!
This is the best and IMO THE ONLY ADVICE THAT MAKES SENSE. Until this is done (i.e. getting some actual FACTS) it's all guesses and probably bad ones at that.
Larry
โOct-19-2018 02:46 AM
Get it weighed!
โOct-18-2018 07:59 PM
โOct-18-2018 06:33 PM
