Adding a Hitch To The Trailer
TheDirtBiker
Hey Guys newbie here, hope I found the right forum for my question.
I've just put down a deposit on a 2018 Tracer 24DBS
http://primetimerv.com/product-details.aspx?LineID=475&Image=24433&ModelID=3690#Main
I want to add a receiver to the rear of the trailer so that I can use a "hitch hauler" to haul two dirt bikes (less than 500lbs, more than 400) My wife is FREAKING out that I want to do this because when you read the fine print Tracer says that you cannot add anything to the bumper or the rear of the frame.
Now common sense tells me that this frame is a pretty beefy piece of I Beam steel. I have a buddy that's a fabricator (and mechanical engineer) and we were planning to either use one of the standard recievers below that appear to support up to 500lbs tongue weight or fab something up ourselves.
So what do you guys say, should I listen to the wife or am I right that it's not a big issue and I won't have any problems?
http://www.buyautotruckaccessories.com/curt-adjustable-rv-trailer-hitch-cur13701.html?utm_source=bing&utm_medium=cpc&utm_campaign=SC_PLA_CURT%20Manufacturing&utm_term=1100404023410&utm_content=CURT%20Manufacturing%20-%20All
60 REPLIES 60
Bedlam
Moderator
Moderator
Seon wrote:
Clearly the OP has made up his mind on doing it so here's my suggestion,
either buy or have you fabricator build a double swivel wheel trailer.
Problem solved.
http://www.cruiserlift.com/swivelwheel-58-dual-wheel
I agree this is best solution while keeping the same travel trailer. This maintains your tongue weight and keeps stresses low on your trailer frame.
klutchdust
TheDirtBiker wrote:
carringb wrote:
JIMNLIN wrote:
Hang in there biker. We have some folks don't believe in towing doubles (2 trailers). In my state we actually tow RV triples (3 trailers) mostly in the summer (5th wheel trailer/ski boat/PWC trailer ....or load of ATVs/bikes.)
I'm pretty sure he's not asking about double towing. He wants to put a double-motorcycle carrier back there.
I am considering multiple options but I would prefer to use a hitch hauler. I have a Kendon motorcycle trailer that weighs 420lbs I would consider towing behind the trailer. I plan to speak with the CHP to see what's legal in Ca hopefully this next week.
What's legal in California is the first trailer has to be a fifth wheel. You don't have one. You bought the wrong trailer for your needs, bummer.
TheDirtBiker
TheDirtBiker
Adam H wrote:
z_g wrote:
Isn't the issue of exceeding manufactures recommendation, in this case you are assuming all liability should something happen. Your insurance won't cover and likely if you are involved in an accident your configuration could be suspect and contribute additional damage. It's not about the physics of towing and if it could be done... It's if it should be done... We all share the road with your choices here..could the bikes find a different way to join you...
I guess anyone with a hotrod or lifted truck should be worried? I call BS on this and the worst part is this type of hype is said daily here.
Thanks for the encouragement, I'm not in this to make a quick or brash decision but I know it can be done as I see it being done when I go to the races. I've also got a friend who's a real good fabricator (mechanical engineer too who designs medical devices) so I know if we take our time we can get it done.
So far I think I need to build a support that goes all the way up to or forward of the axles that has a K design with dual recievers.
JIMNLIN
Read ALL my reply as I addressed that 400-500 lb issue hanging on the rear of the trailer.
pauldub
TheDirtBiker wrote:
I am still curious though for you guys that tow a dingy, how much time weight do you put on the rear of your trailers? Am I mistaken that isn't what this post of the forum is for? Clearly you guys are putting some load on the trailer frame or am I completely wrong?
Most people are towing a dingy behind a motor home, I don't think I've ever seen one behind a travel trailer. Tongue load is only half the weight of the tow bar, maybe 30 pounds. Maybe there is a creative way you can get both bikes in the truck. Possibly with the front wheels over the cab.
carringb
2014 ORV really big trailer
2015 Ford Focus ST
drsteve
Insurance is there to cover when the insured has an accident, makes an error in judgement, or just plain does something stupid. Of course they'll pay.
2006 Silverado 1500HD Crew Cab 2WD 6.0L 3.73 8600 GVWR
2018 Coachmen Catalina Legacy Edition 223RBS
1991 Palomino Filly PUP
Adam_H
2007 Fleetwood Avalon HW PUP
2001 Excursion 6.8L V10 3.73
2005 F150 5.4L
Gone but not Forgotten: 1971 Trailstar PUP, 2002 Fleetwood Wilderness Northwest Edition, 2002 Keystone Bobcat 280-EB
JIMNLIN
I double towed with a 26' 5th wheel trailer and a 3400 bass boat for over eight years. Hitch weight was 220 lbs. I also tow agriculture doubles.
I had a weld shop custom fab the hitch to the trailers main frame rails/crossmembers all welded. The shop used 1/4 wall 4" square tubing along side the main rails including the first axle and across the rear....and 3" square tubing for cross members.
400-500 lbs is a huge amount of weight way out behind the trailers axles unlike our trucks. Apples vs oranges.
Some Rv trailers main frame rails can be very weak as the units sidewalls/roof give the unit overall strength unlike a truck or a flat bed trailer where the heavy main frame rails/16" on center cross members are its strength.
As I said rv trailers main frame rails are pretty gimpy on some smaller trailers so do your home work on bracing the frame to carry more weight so as not to pull the sidewalls loose from the units floor. I always have my fab shop include the rails including the axles. Good luck on your new project
drsteve
You're not looking for advice, you're looking for confirmation. I can tell you from personal experience, loading large amounts of weight on the back of a TT is a bad idea.
As for towing doubles, it works great, but the first trailer has to be a fifth wheel in every state I know of.
Good luck.
MWJones
X2 on Toy Hauler !!!
M Jones
American and Texan by birth
Christian by the Grace of God
Retired and enjoying Traveling and Camping
Spending part of summers in South Fork, Co
nickthehunter
Nomad II
Nomad II
Why don't you just get a Toy Hauler TT? That's why they make them. Problem solved and no fabrication needed.
JBarca
Nomad II
Nomad II
Hi DirtBiker,
I will try to help you see some of the issues. Some are easier to work through then others.
First is the TT weight and balance. If I found your camper correctly, Yes/No? See here Tracer Specs The 24BDS has a dry (empty) VUW of 4940# with a empty tongue weight of of 505#.
Your camper is starting at 10.2% dry tongue weight (TW). That is the bottom end of TW for stable towing. You need to load the camper to get it up ideally into the 13% or higher range. And with that floor plan and the amount of storage upfront it will allow you to get there. So now the camper is balanced well with just your camping gear.
When you add weight on the back you will start losing TW from what you just gained by adding the camping gear. The camper will have to be balanced out again and not go over the tires/axles limit or GVWR of the camper. Have your engineer friend can do static moment calculations about the camper axles to determine how much more weight you need to add up front to offset the rear overhung load of the hitch platform on the back to get back into that 12 to 13% TW range.
If you add 500# in the back say 8 feet behind the center of the axles, you have to add 500 more pounds 8 feet forward up front from the axles to offset the overhung load on the hitch platform. That is 1,000# more to the camper just to get it back to the needed balance before you added the bikes, frame etc. Part of the issue is, that floor plan and where they placed the axles the camper starts with a very low dry TW. Coming up with 500# more gear forward of the axle will take some work.
You will need to keep track of just how high in weight the loaded cargo is to not go over the GVWR of the camper and the axles/tires.
Next is the rear axle loads. When you add the 500# that X feet behind the rear axle hanger, the rear axle will take on more weight than just the 500#. Again your engineer friend can calculate the moments above the rear axle and see just how far you are from your rear axle rating. With that much weight, that far back you might overload the rear axle. It is something to check. You probably only have 3,500# axles.
Next is the main frame rails. Your camper is a 7,505# GVWR rated camper frame. The RV industry sizes these frames to the bare minimum. The word "beefy" is an oxymoron when it comes to RV frames. You stated it was an "I beam". It is more of a I shape and is very thin with ultra week flanges. Odds are high a frame sized for that rating is maybe only 6" tall and 1/8" thick center web and lower flanges. The problem is the concentrated load overhung behind the rear axle hanger. The area behind the rear axle hanger is the weakest spot for the overhung load.
When you hit a pothole doing 50mph the impact loads into the trailer frame is massive and that overhung load is not your friend at this point. Does your camper have shock absorbers or a rubber equalizer? Most do not, but yours might. It is much worse without the shocks. Have your engineer friend calculate the moment of inertia of the frame section. You will have to figure out if your frame is made from 36ksi yield steel or 50 ksi. Hopefully it is at least 50ksi yield strength steel. They do make them from high strength low carbon steel (HSLC) just I do not know if your is.
He can then back into what is the maximum bending moment at the rear hanger along with the maximum stress of running over a pothole at speed. That will then tell if the stress are high enough to blow out the lower flange on the frame behind the rear axle hanger as that is where the failure will most likely fail first. Have him look up inelastic flange local buckling. Basically it means the lower flange will permanently deform from the bending loads and the frame rail will no longer be straight or can handle the normal towing loads without added deflection.
These camper frames are not made like an industrial flat bed trailer that has a lot of steel in them with tall thick frames and lots of frame reinforcing.
Potholes and bumps are an unfortunately realty to towing a camper. I suspect your engineer friend will find that there is very little to no safety factor left in the frame with 500# of bikes and bike rack attached to the back of the camper. If that amount of weight can be over the axles, then no problem. Yes I'm sure they can create a mount to hold the bike platform to the trailer frame, but that is not the weak point. The whole frame rail is.
From what I have learned, I would not attempt a loading like that unless the main frame rails had a minimum area moment of inertia of 51 in.^4 with added lower flange reinforcement to prevent the buckling and made from 50ksi steel or higher. That and shocks and a rubber equalizer is a must. Odds are high your frame rail is not 1/2 of the size needed.
Hope this helps
John
2005 Ford F350 Super Duty, 4x4; 6.8L V10 with 4.10 RA, 21,000 GCWR, 11,000 GVWR, upgraded 2 1/2" Towbeast Receiver. Hitched with a 1,700# Reese HP WD, HP Dual Cam to a 2004 Sunline Solaris T310R travel trailer.
Y-Guy
Moderator
Moderator
Since this is not about Dinghy towing I'm moving this to the Towing forum.
Two Wire Fox Terriers; Sarge & Sully
2007 Winnebago Sightseer 35J
2020 Jeep Gladiator Rubicon
