Dittos on what Trouble Waters said except that you should not need to paint-to-match because you will never see it when the top is down and the plate will be on the outside of and tight against the softop when raised.
Keep an eye on those rear plates where the lift mechanism fastens... that wood can weaken over time and it is a real bear to fix. I had to do it on my '94 NorthStar and it it takes some effort to repair.
Sold the TC, previous owner of 2 NorthStar pop-ups & 2 Northstar Arrows...still have the truck:
2005 Dodge 3500 SRW, Qcab long bed, NV-6500, diesel, 4WD, Helwig, 9000XL,
Nitto 285/70/17 Terra Grapplers, Honda eu3000Is, custom overload spring perch spacers.
