Aftermarket TV Wheels
thirtydaZe
Sorry for yet another unusual question, been doing a ton of brainstorming leading up to our walk through on our new camper.
I put a set of XD monster wheels on my truck last year. My tires are rated for 3700# and some change, however i was doing a search, and it looks like the wheels are only rated at 2200.
I'll be approaching 2200 quickly. Not knowing much about wheels and tires, is this a legitimate concern?
I still have the stock set in my possession, but am running out of time, as we are taking delivery wednesday, and then leaving for 2 weeks friday.
2019 Jayco Eagle HT 324BHTS
2024 Ram 2500 68RFE
12 REPLIES 12
BenK
thirtydaZe wrote:
I see now that they do make this wheel with a 3200# load rating, maybe they matched the correctly.
Any clue if a wheel contains a visible part number?
NVM. i see now that all the wheels with an 8 bolt pattern are rated at 3200.
thanks.
Most are marked, but have been corrected by capri that it is NOT mandated
by DOT like I thought
Some are painted, some are embossed, some on the back side, some are
on the portion covered by the tire, etc
Here is what is on my local fire department's engine while was touring
their new trucks and engines
firetruck fireengine alloywheelrating
firetruck fireengine firetruckwheel alloywheelrating wheelrating
-Ben Picture of my rig
1996 GMC SLT Suburban 3/4 ton K3500/7.4L/4:1/+150Kmiles orig owner...
1980 Chevy Silverado C10/long bed/"BUILT" 5.7L/3:73/1 ton helper springs/+329Kmiles, bought it from dad...
1998 Mazda B2500 (1/2 ton) pickup, 2nd owner...
Praise Dyno Brake equiped and all have "nose bleed" braking!
Previous trucks/offroaders: 40's Jeep restored in mid 60's / 69 DuneBuggy (approx +1K lb: VW pan/200hpCorvair: eng, cam, dual carb'w velocity stacks'n 18" runners, 4spd transaxle) made myself from ground up / 1970 Toyota FJ40 / 1973 K5 Blazer (2dr Tahoe, 1 ton axles front/rear, +255K miles when sold it)...
Sold the boat (looking for another): Trophy with twin 150's...
51 cylinders in household, what's yours?...
Bedlam
Moderator
Moderator
thanks.
3200# is still 500# lower than tire rating....wrong wheels
What is the axle rated for ? If it's a 6K axle then the wheels are the not the weak link in the chain, the axle is.
If it is an 8-lug rim, this is most likely a 3/4t or 1t truck. These trucks have axles that are rated around 10,000 lbs from the supplier and derated by the vehicle manufacturer for the application (vehicle class).
BTW: I had a F250 with the 9750 lb Sterling 10.5" axle. I ran 4500 lb Vision Heavy Hauler rims with 4800 lb LRH 14PR tires. The weak link in my setup was the rims which gave me a 9000 lb rear axle rating. Typical rear axle weight for me was 7000-8000 lbs which push the limits of 3650 lb OEM rims and tires too much.
mowermech
copeland343 wrote:
You need to change out your wheels. They are for show not towing
My sentiments exactly!
CM1, USN (RET)
2017 Jayco TT
carringb
I have cracked two aluminum wheels due to overloading. One of them cracked between each of the lug holes, the other cracked near the valve stem. I took those off and replaced them with OEM Chevy wheels (machined to fit my Ford).
2014 ORV really big trailer
2015 Ford Focus ST
gmw_photos
thanks.
TXiceman
Personally, you are better off sticking to the OEM wheel and tire size.
Ken
Amateur Radio Operator.
2023 Cougar 22MLS, toted with a 2022, F150, 3.5L EcoBoost, Crewcab, Max Tow, FORMER Full Time RVer. Travel with a standard schnauzer and a Timneh African Gray parrot
goducks10
I ran into the sane issues when going from 17" to 18" tires this year. I was looking at 18" rims at Discount tire and the guy doing the research actually called the manufacturer of the rims I was interested in. Ironically one set that was rated high enough was not recommended according to that manufacture since I was towng a 5th wheel. It took awhile to find the set I needed that had the right weight ratings. I too found lots of cool looking rims with 2200-2500lb ratings even though they had 8 lugs which according to Les Schwab was all you needed to worry about. Pays to shop around.
copeland343
Wheels need to have a higher rating than the tires.
Old-Biscuit
thanks.
thirtydaZe
thanks.
2024 Ram 2500 68RFE
Old-Biscuit
That's why the wheels have ratings.........
Those tires should never have been matched with those wheels. Very misleading cause one can easily check tire rating (on sidewall) but not when it come to wheels (hidden)
You need wheels that match or exceed tire ratings.
All show but NO GO!
copeland343
