โFeb-20-2016 01:58 PM
โFeb-26-2016 05:57 AM
โFeb-26-2016 03:49 AM
โFeb-22-2016 12:53 PM
โFeb-21-2016 06:36 PM
โFeb-21-2016 11:17 AM
Lynnmor wrote:timmac wrote:
Never know when you might need that extra 5 hp.. ๐
Yes, if you find that you operate at wide open throttle a lot, then you can go a wee bit faster with a few more horsepower. If you don't operate at wide open, then what does anyone expect to gain with modifications?
I don't know anyone that tows with their foot flat on the floor.
โFeb-21-2016 11:11 AM
โFeb-21-2016 10:36 AM
Turtle n Peeps wrote:timmac wrote:Turtle n Peeps wrote:
It's your money but you will pick up next to nothing. Kind of like flipping the air cleaner lid over in the old days. The only way to deal with those altitudes is supercharging.
Well if you set it up right from the start with headers to go with the cold air intake you can see gains in HP.
Check out this video with just the cold air intake, they were to prove it would do nothing but by surprise it gained some HP.
https://youtu.be/xwNtjKT_1cA
To compare a high performance, high RPM Honda engine to a tow vehicle engine is to compare apples and hippopotamuses.
Like I said. You will pick up next to nothing. Let me do the math and define what I consider next to nothing.
You take a Hemi that puts out 400 HP at sea level and you put it at 11,000 ft like the OP was talking about and that same Hemi that put out 400 HP at sea level will now put out around 270 HP. A loss of around 130 HP.
Lets say you at a cold air system and it give you 5 more HP. Big woop, you made 5 HP of the 130 you lost in the first place. That is my definition of next to nothing.
โFeb-21-2016 10:27 AM
dodge guy wrote:
To the OP, you may want to consider a custom tune from Black Bear tuning. they are THE tuner for GM trucks!
What gearing does your Burb have? if 3.73 a swap to 4.30 or so will be a good choice for mountains!
โFeb-21-2016 10:12 AM
โFeb-21-2016 10:10 AM
Old-Biscuit wrote:
Like I posted on other site.......COLD air in and need to increase Exhaust out
That filter set up sucks HOT air from under hood. Not an improvement.
โFeb-21-2016 07:59 AM
โFeb-21-2016 07:10 AM
โFeb-20-2016 07:12 PM
โFeb-20-2016 06:46 PM
