Feb-21-2019 12:40 PM
Feb-23-2019 07:08 AM
NRALIFR wrote:
It’s likely that wasn’t a typical cloud to cloud, or cloud to ground lightning strike. Helicopter triggered lightning strikes are a studied but not well understood phenomenon. The part of the helicopter struck is almost always the main or tail rotor blades. As you are probably aware, helicopters acquire a strong negative charge when they fly through air because of static charging. Strong enough that if you were to touch a hovering helicopter while standing on the ground, you could be seriously hurt or killed. I suspect the “strike” you experienced was induced when the helicopter you were flying flew into a positively charged area around a storm cloud. It was probably of lower intensity than a typical cloud to cloud or cloud to ground lightning strike, but strong enough to cause the damage you found.
Feb-23-2019 06:35 AM
am1958 wrote:
Many years ago in Belize a pilot and I were returning from tasking in the middle of the country in an RAF Puma helicopter. It was the rainy season and we found ourselves cornered by thunderstorms and in an area of the jungle where there were no landing sites so we pushed on through the weather. After landing I got out to do the After flight checks which included checking the rotor blades. There was a small "blister" about the size of a quarter on the underside of one of the blades so I got the ladder out to inspect it. There was an identical "blister" on the top side of the blade in the same place. I called over a senior tech and showed it to him. He immediately identified it as a lightning strike. Funny thing was neither the pilot nor myself had any idea it had happened...
Feb-23-2019 05:22 AM
Chum lee wrote:
Not to hijack the thread, but, out of interest: (I'm a pilot)
What did the tech recommend as a repair?
A. Replace the blade
B. Repair the blade
C. Nothing
D. Other (please specify)
How was the blade fabricated? (material)
Thanks,
Chum lee
Feb-22-2019 01:40 PM
Feb-22-2019 11:24 AM
mich800 wrote:
So it is a shocker lighting can cause a fire? Must be a conspiracy about the forest fires started by lighting strikes.
Feb-22-2019 10:12 AM
am1958 wrote:
Many years ago in Belize a pilot and I were returning from tasking in the middle of the country in an RAF Puma helicopter. After landing I got out to do the after flight checks which included checking the rotor blades. There was a small "blister" about the size of a quarter on the underside of one of the blades. There was an identical "blister" on the top side of the blade in the same place. I called over a senior tech and showed it to him. He immediately identified it as a lightning strike. Funny thing was neither the pilot nor myself had any idea it had happened...
Feb-22-2019 07:49 AM
Feb-22-2019 05:55 AM
Rover_Bill wrote:JaxDad wrote:
What does the truck being made of aluminum have to do with it being struck by lightning? It’s no more or or less conductive than any other metal used in automotive body construction.
The heat of the lightning strike starts the interior on fire instantly and it doesn’t matter what metal it’s behind, it all conducts heat the same.
Pictures from the recent California wild fires showed a lot of burned out steel body pickups and cars. None that I can remember showed any with a totally burned off roof or engine hood like in this one. Just sayin.
Feb-22-2019 05:37 AM
Feb-22-2019 05:16 AM
free radical wrote:Rover_Bill wrote:
Aluminum wiring was band many years ago because it can cause house fires when arching. This is what happened when lightening hit an aluminum body Ford pickup. :E
Clicky
FAKE NEWS
Lightning cannot start car fire aluminum or any other
https://youtu.be/olxaFBtCV4Q
Feb-22-2019 03:53 AM
Feb-22-2019 02:08 AM
Feb-22-2019 01:46 AM
Feb-21-2019 07:24 PM
Clicky
