Battery Hook-up Question
ianmac23
I am building a new battery box for the two golf cart batteries that I just purchased. I also adding a marine battery cut off switch. My question is if I disconnect the battery once the RV is plugged in to shore power will the 12v items on the RV still work? Can I use my good portable 3-stage charger with the positive hooked to the RV and the negative disconnected?
Thanks for the help
Ian
2010 GMC Sierra, 1500, SLT, Crew Cab, Short Bed, 6.2L, Max Towing Package,2011 Keystone Passport Ultralight Limited Edition
15 REPLIES 15
martipr
prichardson wrote:
Why would you want to disconnect the batteries when on shore power? Some of the on board chargers(converter) will carry the 12V systems; however, for most it is better that they see a battery. A separate charger would need both its + and - connected to the battery bank.
If you have a single stage converter/charger and leave the battery connected while on shore power it will boil the battery dry quickly. Don't ask me how I know!!
Old Navy Chief (AOC) Retired Aircraft Mechanic/Inspector
2007 29' 27FBV Trail Bay V Series
2015 Dodge Ram 2500 Crew Cab 6.7 Cummins Diesel
Reese Strait-Line Dual Cam Hitch
RoyB
This is typical 30AMP trailer wiring configuration...
AS you can see here the 12VDC Power distribution Panel is ran by both the on-board converter/charger unit and/or a battery.
If you disconnect the battery when on SHORE POWER your trailer system will still run just fine from the 12VDC power Distribution Panel that is powered by the on-board 120VAC converter/charger unit.
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
ianmac23
Thanks for all the information
OnaQuest
wa8yxm wrote:
A Progressive Industries, Intellapower 9200.. now that is one heck of a converter.
The Intellapower (sic) 9200 is made by Progressive Dynamics, NOT Progressive Industries. ........It's Intellipower.
wearenh
wa8yxm wrote:
A Progressive Industries, Intellapower 9200.. now that is one heck of a converter. From the research I have done, if you have flooded wet cells. it is #1,, A few others fall into the same quality band but none better.
Here is the 9260 for only $172 including shipping
2007 Gulf Stream 6211 (21' Shorty) Ford E350 V10
sometimes with #14 Racecar (18' KwikLoad Rollback)
sometimes with two gaited horses (Featherlite 9407)
sometimes just us camping with our dogs
wa8yxm
There are basically 3 types of converters for this discussion.
The Magnetek 6300 Series is the one that is well known for boiling batteries dry, It also will not work without either a battery or a "Battery Simulator" which of course is no longer sold.... Under that name.
You can get a hardening condenser or hardening capacitor (Same thing) at a high end audio shop. these are typically multi-farad capicators with around a 20 volt rating,, They are... The same as the Magnetek simulator.
Most modern singnle stage converters do not necessarly bring the battery to full, but they also do not boil it dry.
beemerphile1
ianmac23 wrote:
I am not sure of the exact converter. I have a 2011 Keystone Passport Ultralight.
All 2006 and newer can operate without a battery.
Still need to know the converter.
Fact is you can have the batteries charging from the converter and portable charger at the same time.
You are making assumptions based on what you read which may or may not be relevant to your system. Don't believe everything you read and don't make life harder than it needs to be. Your system was designed to operate the way the factory built it. Improvements can be made but until you really understand how the systems operate just leave them alone.
Spend many hours and hours on here educating yourself. Once you thoroughly understand how everything works, then you start making modifications. Before that, do yourself a favor and leave it alone.
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
ScottG
Then you will be fine running without a battery except possibly when it comes to running the slide in and out - keep the battery connected for that.
ianmac23
beemerphile1
Ian, maybe if you start over and tell us what converter you have we can give better answers. Your profile doesn't even give year of your trailer.
Water-Bug
Running your RVs 12 volt electrical system with the battery disconnected IS NOT a good idea. Items like slide out motors can draw more than the circuit is able to provide.
pianotuna
Nomad III
Nomad III
Hi,
Some older converters required a battery to be "in the loop" to even out the voltage.
Unless the rv is going to be plugged in for several weeks I'd let the converter do it's job.
Regards, Don
westend
Yes, the 12v items will still be powered by the onboard converter while on shore power, in most cases. Some RV's will need the batteries in the circuit to power the 12v system correctly, they buffer the output of the converter's power supply.
Your stand-alone charger will work with batteries disconnected by the switch if you have the charger's leads connected to the (+) and (-) terminals of the batteries. Hooking the leads into any other wires while the ground is interrupted, will not complete the circuit so no charging will take place.
12 volt side of life
'03 F-250 4x4 CC
ianmac23
I have read a lot on how the onboard charger from the factory is not a 3 way charger and how it won't charge properly. I can't afford to upgrade the inverter this year so I was just going to use my 10amp battery tender to charge it when we are camping.
