Battery Hook-up Question
ianmac23
I am building a new battery box for the two golf cart batteries that I just purchased. I also adding a marine battery cut off switch. My question is if I disconnect the battery once the RV is plugged in to shore power will the 12v items on the RV still work? Can I use my good portable 3-stage charger with the positive hooked to the RV and the negative disconnected?
Thanks for the help
Ian
2010 GMC Sierra, 1500, SLT, Crew Cab, Short Bed, 6.2L, Max Towing Package,2011 Keystone Passport Ultralight Limited Edition
15 REPLIES 15
prichardson
Why would you want to disconnect the batteries when on shore power? Some of the on board chargers(converter) will carry the 12V systems; however, for most it is better that they see a battery. A separate charger would need both its + and - connected to the battery bank.
