โMar-10-2018 09:55 AM
โMar-10-2018 06:26 PM
โMar-10-2018 05:59 PM
โMar-10-2018 04:36 PM
lawrosa wrote:
The campground only needs to shock the well at the start of the season... They probably are not doing that or dont know how..
https://www.cleanwaterstore.com/resource/how-to-guides/how-to-shock-chlorinate-sanitize-wells/
โMar-10-2018 04:13 PM
wa8yxm wrote:
There are many technologies to filter and/or treat water.
For Bacteria an "Ultra Violet" treatment will take care of most of 'em. Please do not ask me more as this is an area I have never studied.
Carbon filters take care of most taste/odor issues but if you have high Sulfur or high iron you may need special filters.
Micron filters (The smaller the better) may also stop bacteria but they also reduce pressure.
I would have the well water tested and ask the lab to suggest filtering.
โMar-10-2018 03:08 PM
โMar-10-2018 02:42 PM
ScottG wrote:darleyhavidson wrote:naturist wrote:
My Master's degree is in water/waste water chemistry/civil engineering.
There is no practical way to ELIMINATE those water supply bacteria. No water system on the planet (that operates at reasonable cost) can do it. You can't either.
My suggestion to you is this: sanitize your RV water system a couple times a year, and run lots of water through it.
Use either chlorine bleach, or hydrogen peroxide (my preferred way) to sanitize, then use water freely. The smell develops when the water stagnates. It is a product of the anaerobic bacteria, perfectly normal, and to be expected. It will develop faster in water from a well or spring that is not treated with chlorine, partly because the chlorine knocks down (but does NOT sterilize) the bacteria level, and partly because the chlorine is an oxidizing agent that removes the sulfur.
Thanks for the information. What method do you use when sanitizing with Hydrogen Peroxide? What concentrate of Hydrogen Peroxide do you use?
I'm curious about using Hydrogen peroxide as well. I would think it would have to be used full strength?
โMar-10-2018 02:38 PM
lawrosa wrote:Boon Docker wrote:
The cause of the smell is iron bacteria. Replacing the anode rod will not solve the problem. The only way the rectify the problem in the short term is have the campground shock chlorinate the well.
BTW - Iron bacteria is not a health concern, just a nuisance.
Ditto. As I stated in my post above. But it will cause the sulfer smell.
As stated your best off just using the fresh water tank onboard.
Fill tank and some bleach. Look for tables on how much. You dont need a lot.
It may be a pain but this is how we treat the homes with same conditions.Bleach injection.
Youll have to continually fill the tank as you use it to empty.
Try that and see if your issues go away.
Also use the cheap camco carbon filters from walmart to fill the tank..
2 packs should be around 20 bucks.
https://www.homedepot.com/p/Camco-TastePURE-Water-Filter-KDF-2-Pack-40045/205518952
A more permanent solution would be to get some sort of inline pool chlorinator to put inline with the outside water line.
Example here.
http://www.vitasalus.net/inline-chlorinator-chlorine-feeder-system
And then put one of those tanks in the rv that reduce pump run time. This will be used as the mixing tank.. ( Accumulator)
But don't use the small ones they sell for rv's. Install a 2.5-5 gallon potable water expansion tank. After All that's all what those expensive units are that you but for rv';s.
Exp tank install shown here.
http://wannabrv.akom.net/archives/12-RV-Expansion-Tank-Installation-in-the-trailer.html
I dont have a PHD or masters degree like the poster above, but I am a plumber some 30 plus years.
Its the same as treating pool water. Infact my pool after adjusted for 2ppm chlorine ( Chlorine is sodium hypochlorite which is same as bleach) alkalinity and PH can be drinkable and a better standard then what comes out of city taps...
I treat my pool with bleach, baking soda for alkalinity, and borax 20 mule team for PH adjustment.
โMar-10-2018 02:30 PM
โMar-10-2018 02:26 PM
โMar-10-2018 02:16 PM
โMar-10-2018 02:06 PM
โMar-10-2018 02:05 PM
โMar-10-2018 01:49 PM
โMar-10-2018 01:37 PM
โMar-10-2018 01:34 PM
