Black Holding Tank slow to drain...
mgirardo
Our Black Holding Tank is slow to drain. Can this be caused by a bad Air Admittance Valve or a clogged vent cap or both? The tank dumps fine at first, but it eventually backs up and then very slowly drains. The grey tank does not do this. It flows just fine.
Thanks in advanced,
-Michael
Michael Girardo
2017 Jayco Jayflight Bungalow 40BHQS Destination Trailer
2009 Jayco Greyhawk 31FS Class C Motorhome (previously owned)
2006 Rockwood Roo 233 Hybrid Travel Trailer (previously owned)
1995 Jayco Eagle 12KB pop-up (previously owned)
21 REPLIES 21
schlep1967
Sounds to me like you may have the disk they cut out to install the drain line still in the tank. As everything moves towards the drain it brings the disk with it until it gets to the tight spot then it jams up.
2021 Chevy Silverado LTZ 3500 Diesel
2022 Montana Legacy 3931FB
Pull-Rite Super Glide 4500
K_Charles
2oldman wrote:
You can verify if it's air intake by holding open the toilet.
This X 3
MarkTwain
1. put a water hose in the toilet and fill black tank about 3/4 full then open black tank valve, leaving the water hose running. Repeat process 2 or 3 times. If this does not resolve the issue call the local septic tank removal business and have your tank emptied.
Sam_Spade
kgie1217 wrote:
Sounds like you have a build up of waste (ie, toilet paper, feces). Have you done a flush yet?
This.
And this.
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
korbe
Backs up?
2oldman
kgie1217
2016 Crossroads Sunset Trail Ultralite 250RB
