โJun-09-2023 10:28 AM
โJun-13-2023 08:28 AM
Cummins12V98 wrote:HappyKayakers wrote:
Maybe you can tell that to the states who get their water from the Colorado River. The same ones who just had to hammer out a new agreement on water usage with a lot of cuts.
While your claim may or may not be true, this planet has never been host to so many humans who use water without thinking of the consequences.Cummins12V98 wrote:
OMG.......
"After reading about various water shortages across the country, I'm perfectly happy with using a probiotic in the tank and conserving water."
You do understand that the amount of water on this planet has NEVER changed??????
Best go back to the Cave.
YES it's true.
โJun-13-2023 07:01 AM
OMG.......
YES it's true.
โJun-13-2023 07:00 AM
โJun-13-2023 06:58 AM
chops1sc wrote:
I am 1000% in favor of using as much water as you can while using the camper. But if the camper is in storage mode, I feel like a chemical would help with the smell.
โJun-13-2023 06:24 AM
OMG.......
โJun-13-2023 05:57 AM
Cummins12V98 wrote:
OMG.......
โJun-12-2023 07:37 PM
โJun-12-2023 06:07 PM
The real question is how to you handle potential odors in your system. Some use chemicals and others simply use lots of water and empty tanks regularly. I do believe that both work. If you don't want to use chemicals, use water.
โJun-12-2023 06:03 PM
โJun-12-2023 06:02 PM
cummins2014 wrote:Cummins12V98 wrote:pbeverly wrote:nickthehunter wrote:
Calcium Nitrate is the chemical often used in black tank treatments. It is also used in wastewater treatment plants for among other things - guess what - odor control. It does not kill the bacteria beneficial to breaking down waste. The perfume smelly additives are generally organic citrus products and similarly harmless. Use the stuff if you want, or not, whatever floats your boat.
RVs have holding tanks not septic systems. The holding tanks aren't designed for decomposition as nothing stays there that long.
ZACTLY!!!
This is quite a funny debate ,as we experienced RV guys know , water ,water ,water .I have used those drop in packets off ,and on for years. They make little difference , if any .
โJun-12-2023 04:13 PM
โJun-12-2023 08:52 AM
ZACTLY!!!
โJun-12-2023 06:50 AM
ZACTLY!!!
โJun-12-2023 06:35 AM
Grit dog wrote:aftermath wrote:JIMNLIN wrote:
....I also use coconut oil to keep the valves lubed.
No smelly tank issues.
And, how exactly, do you do this? Just pour some down the toilet? Do you add some after you have dumped the tanks? I just had to replace my two valves in my 2006 trailer. Looking for a simple way to do some preventative maintenance here.....Thanks.
Not those valves. I think. But thereโs a reason this hit 4 pagesโฆ.lol
โJun-12-2023 06:32 AM
ZACTLY!!!
