โMay-21-2015 07:38 PM
โMay-24-2015 04:30 PM
restlesswind wrote:
My SIL has a Prodigy brake controller on his Ford P/U. ('05 4wd 3/4)
The brakes on the trailer work using the manual control but no trailer brakes when pressing the brake pedal on the truck.
Any advice?
After checking all that the instruction book called for SIL found the book!) we narrowed it down to the controller itself .New one on order.
Thanks for all the help and advice, we both learned a lot.
โMay-22-2015 07:52 AM
โMay-22-2015 06:58 AM
โMay-22-2015 06:17 AM
cbenn wrote:
Let me save you some time, on your Ford if you can stop the trailer with the controller and not with the brake pedal your TBC pressure transducer is out, it is located directly under your master cylinder, there are 2 sensors there, the front one is more for the brakes/cruise control, the second one is the transducer for trailer brakes, ford carries them at a whopping $154.00, go on line and should find them for around $100.00. Hope this helps you out.
โMay-22-2015 03:41 AM
restlesswind wrote:
We will hook up the trailer tomorrow ,get the volt and current meters out and get some more information.
Artum Snowbird....That was my first thought. Unfortunately, he has lost the instruction book. (?)
โMay-21-2015 10:49 PM
โMay-21-2015 08:08 PM
Any advice?
Do his brake lights come on? The TT brakes are activated when the TV brake lights come on.
โMay-21-2015 08:06 PM
โMay-21-2015 08:00 PM
Any advice?
โMay-21-2015 07:44 PM
