CB or Ham Radio good to get in contact to other RVers?
jamescook
Hi,
next May, we want to start on a 4 months trip though the United States with our own RV (shipped from Germany).
Do you think is worth to have a CB or ham radio installed for this trip? (I would get a technician class license, if ham makes sense)
I'm talking about close range communication, like chatting while passing on a highway. I don't like big antennas on my small Sprinter Van. Getting in contact with other RVers and residents is our main focus for this trip, not visiting the touristical hightlights.
Regards
Peter
KK6IMU
_____________________________________
81 REPLIES 81
jamescook
marcsbigfoot20b27 wrote:
I think it would be cheaper to buy here then sell when you are done.
Hi Marc,
are you talking about ham radio gear? Or do you suggest buing an RV?
Peter
KK6IMU
Bumpyroad
just bought a Cobra 25 LTD Classic on sale at Love's for $69. well $79 with a $10 mail in rebate.
sounds good.
bumpy
marcsbigfoot20b
CB for sure!
Willkommen fellow German!
My German side of the family is in the Koln, Dusseldorf , and Pulheim area.
My Swiss side is near St Gallen and my uncle wants to bring his RV here to travel also.
mowermech
Redsky wrote:
Truckers use CB but very few motorists. Ham or amateur radio required individual licenses and hand held radios are limited as to signal output and antennas used by the Federal Government to protect the users' little gray brain cells. If you have a license the radio can only be legally operated by you and not by anyone else.
GMRS radios are a one time 5-year license (at this time) that provide the same output as the hand held Ham radios but anyone in your family can use the same license, even grandkids. They are a little bit better than the FRS radios which are good for only very short distances.
The radios sold in the USA will have false Watt output numbers that do not correspond to their actual signal output which may be 95% lower. The "4 Watt" radios often put out only 0.1 Watt of signal power.
The Ham, GMRS, and FRS are all line of sight transceivers so they are blocked by buildings, trees, rocky terrain, hills, etc. which is why 1/2 mile is the best that can be expected almost anywhere. They will work great in flat open areas like most of Texas for example but be poor when used in hilly or wooded country or in large cities.
The Ham have the advantage of being able to take advantage of some relay stations that are privately operated in some areas for a small group in a community. The Ham and GMRS can provide much higher signal output with a base 12v radio installed in a vehicle and can make use of an external antenna for communicating over a much greater distance.
The combo GMRS/FRS radios are the most versatile and easy to use but the quality and true range varies widely. The best ones will be over $100 each but some people are happy with the $20 ones when used around a campground area. Check the reviews on Amazon.com for the different models and you will get a good idea of which ones work better in actual use than others.
"If you have a license the radio can only be legally operated by you and not by anyone else." True, with exceptions. In the event of emergency, anybody can use the radio. Even if there is no emergency, anybody can use the radio with the Station Control Operator's permission and supervision.
"The "4 Watt" radios often put out only 0.1 Watt of signal power."
I have not found that to be true. Most of the radios (CB and Ham) that I have had came out of the box exceeding the rated power.
"The Ham, GMRS, and FRS are all line of sight transceivers..."
That is only true of FM transceivers. AM and SSB and other modes are subject to "skip", and will often talk around the world.
"The Ham have the advantage of being able to take advantage of some relay stations that are privately operated in some areas for a small group in a community. The Ham and GMRS can provide much higher signal output with a base 12v radio installed in a vehicle and can make use of an external antenna for communicating over a much greater distance."
Actually, they are called "Repeaters", and they increase the range of FM UHF and VHF radios to an incredible extent. For instance, around here we have two repeaters that are the most used, because they are linked together. One is on Red Lodge Mountain, the other is on top of the Bull Mountains. These two repeaters give us a communications range from Greybull, WY to Stanford, MT N/S; and from west of Big Timber almost to Sheridan, WY W/E. From my home station or my mobile rigs I can hit either repeater. Both repeaters (and several others in the area) require a 100Hz subaudible tone for access, and can be used by ANY licensed Amateur Radio Operator. Membership in the local club is not required. They can be found at 145.41 and 147.36 Mhz.
"The combo GMRS/FRS radios are the most versatile and easy to use but the quality and true range varies widely."
I had some of those things once. We used them on one trip from CA to MT, then got rid of them. A good CB rig with a good, well tuned antenna is MUCH better! An Amateur Radio license and a 35 watt 2 meter rig with a good antenna is even better!
No code is required for an Amateur Radio license, just get the books from the ARRL, study, and take the test. Most radio clubs have Volunteer Examiners that administer the tests on a regular basis. Or, you can find the test study guides online. The test will cost about $12 to $15, but if you pass the first one you can take the next one or two on the same day with no additional charge. That's what I did; took the Technician test, passed it, then took the General test and passed it. Maybe someday I will study for the Extra Class test. Then again, perhaps not. I don't really need it.
CM1, USN (RET)
2017 Jayco TT
Bumpyroad
I have almost decided on getting a Cobra 18 WX ST II at about $65.
anything better similarly priced? can't find that cobra 21 anyplace
bumpy
Redsky
mowermech
Wadcutter wrote:
Before you post your ham call sign on the internet or using it as your user name do a search on google.com. Ham call signs are listed on Google at fcc.gov and gives your full name and address. If you're OK with that then that's up to you. But at least be aware that your ID is readily available.
Yes, that is quite true. However, if you follow FCC rules to the letter, you will be announcing your call sign frequently over the airwaves, for any short wave listener to hear. It doesn't matter what frequency you use, there is a scanner or short wave receiver that can listen to you.
For that matter, all somebody has to do is drive around looking for towers and antennae, and they can spot a ham operator very easily.
Privacy and security are illusions. There is very little of either in the world of today!
CM1, USN (RET)
2017 Jayco TT
snowpeke
I am a logger and if your on a logging road and it's steep and narrow a cb is a must!
2002 Chevy DuraMax
2014 jayco eagle
Two Pekingese dogs
ol_Bombero-JC
Bumpyroad wrote:
Erie Tom wrote:
evidently you missed the OPs original statement, "I'm talking about close range communication, like chatting while passing on a highway."
a cellphone and GPS are worthless for doing that. a ham radio will let you talk to the folks back home but not to the oncoming trucker who can supply traffic information.
bumpy
There are a lot of truckers that have hung up the mike on the cb and talk 2 meters. They do use the cb but not solo. They want to get away from the trash talk. You do not only talk to the folks back home.. There are a few RV nets at different times of the day giving road reports weather reports and just heads up for any problems that they know of.
I would wager that for every trucker using a 2meter setup, there are about 10000 who have a CB, and those with a 2 meter probably also have a CB running. when approaching a big city, I want a road report NOW, hot different times of the day.
bumpy
Way, WAY more than "10000 who have a CB" - ..:B
jamescook
Thanks for this helpful warning.
I'm lucky, as my (brand new!) callsign KK6IMU only points to a c/o address in California, while I live in Germany. No harm that way 🙂
Peter
KK6IMU
Wadcutter
Camped in every state
John___Angela
Congrats. VE6ROK and VE6ANG
2003 Revolution 40C Class A. Electric smart car as a Toad on a smart car trailer
Life is not measured by the number of breaths we take but rather by the moments that take our breath away.
jamescook
Thanks a lot for so many feedback so far.
Today, I made a big step to my ham radio project. I passed the general class exam 🙂
Peter
KK6IMU
Lowsuv
My friend and I each bought a CB and a magnetic antenna for travelling down Baja .
A handy item for that usage .
We were a convoy of two for 4 weeks .
When I got back I found out that we were illegal operators in Mexico .
We took them out when we returned .
