โSep-24-2021 09:08 AM
โSep-28-2021 12:42 PM
โSep-26-2021 04:54 AM
โSep-25-2021 05:33 PM
fwtraveler1 wrote:
I can not get my RVI battery charger to work towing my 2020 Chev Equinox. Is there another/better system out there for charging a towed vehicle behind an RV?
โSep-25-2021 04:38 PM
JRscooby wrote:Indeed, I mis-wrote in my post. The "always hot" pin was wired to the ignition-controlled circuitry on the MoHo. I don't really want it charging when the rig is shut down.
Not sure "always hot" is the best idea. I think a better idea was have the charge pin controlled by the ignition switch of MH. (If it ain't running, it won't charge anyway)
And the toad end can't be mounted solid, unless you use a removable cord. A switch near toad battery to disconnect would stop a hot wire from causing trouble when not towing.
โSep-25-2021 06:54 AM
โSep-25-2021 06:34 AM
โSep-25-2021 04:51 AM
obgraham wrote:
In the receptacle on the motorhome there is an "always hot" pin. At least there was on mine. I had them run a separate wire from that pin directly to the toad battery.
โSep-24-2021 02:44 PM
โSep-24-2021 11:54 AM
โSep-24-2021 10:41 AM
โSep-24-2021 09:41 AM
