โJun-12-2016 09:12 AM
โJun-15-2016 05:14 PM
shadows4 wrote:skipro3 wrote:dieharder wrote:skipro3 wrote:
I have a large wet/dry vacuum. If I had a clogged black water tank, most likely I'd try hooking it up and opening the tank valve. Once I sucked out what ever was clogging, I'd shut the valve and disconnect the vacuum, empty, clean and put it away.
Once you've sucked out whatever is clogging, the rest of what's in the tank would flow out in the rush you regularly hear in your hose before you get to close the valve. Unfortunately, I've had to be there and do that.
I don't know why you were having trouble to close it off. It's just gravity fed. My tank takes several minutes to drain when it's full.
But, in any case, put the vacuum higher than the black tank. Once the clog comes clear, shut off the vacuum and the flow will stop because the hose is higher than the level in the tank.
I usually try to do things myself but.... in this case the $50 bucks the OP paid,sounds like a bargain to me. No way would I want to clean out the shop vac after that!!!!
โJun-15-2016 05:04 PM
โJun-15-2016 04:12 PM
โJun-15-2016 03:04 PM
Bobbo wrote:
Now, present the bill to the granddaughter. Maybe $50 will educate her.
โJun-15-2016 11:11 AM
โJun-15-2016 10:48 AM
โJun-15-2016 08:53 AM
โJun-13-2016 09:23 AM
โJun-13-2016 07:27 AM
โJun-12-2016 09:38 AM
โJun-12-2016 09:22 AM
