Cold in the bedroom.
swimmer_spe
2023 cherokee wolf pup 22bp
The heat is wonderful.... and not.
It has 2 outlets on either side of the kitchen cabinets. The problem is, with the door closed to the bedroom or bathroom, they get really cold. The doors have a bout a 2 inch gap at the top and bottom.
What do you do to get better heat in the various rooms?
39 REPLIES 39
MFL
Nomad II
Nomad II
^^While above can help in some cases, the OP says he only has two vents in the kitchen.
In the OPs case a small portable heater is about the only option.
Jerry
Mayor30
If you can close the vents in the living room kitchen area, you can force more heat back to the bedroom.
_1Flyboy
โ€ฆโ€ฆ. A good down comforter and then you can turn the heat OFFโ€ฆโ€ฆ..
wa8yxm
QCMan wrote:
Keep the doors open.
"Heat up" the bedroom (Please use your lawfully wedded spouse to help heat).
Another blanket or a poem I once stuck in a box with an electric blanket I gave to a couple of newly weds (Wedding present)
You say our love will keep us warm
No matter how bad the winter storm
But if you're tired some hard day's night
An electric blanket will warm you right.
(Sounds almost like I should add "Burma Shave" as a new last line don't it?)
pbeverly
We like the bedroom cooler. We put a little heater in the bathroom.
Ridgeway, SC
2019 26DBH Grey Wolf
Boon_Docker
Get a cuddle bunny to keep you warm.
pianotuna
Nomad III
Nomad III
Add a large grill in each door.
Regards, Don
dedmiston
Moderator
Moderator
We put a little buddy heater in the bedroom with us.
2014 RAM 3500 Diesel 4x4 Dually long bed. B&W RVK3600 hitch โ€ข 2015 Crossroads Elevation Homestead Toy Hauler ("The Taj Mahauler") โ€ข <\br >Toys:
  • 18 Can Am Maverick x3
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
swimmer_spe
I am trying to avoid that.
QCMan
Nomad III
Nomad III
2020 Keystone Cougar 22RBS, Ram 1500, two Jacks and plenty of time to roam!
The difference between genius and stupidity is that genius has its limits. A.E.
Good Sam Life Member
