โFeb-23-2022 04:31 PM
โFeb-26-2022 05:54 PM
โFeb-26-2022 07:31 AM
โFeb-26-2022 06:23 AM
Brownleaf wrote:
Lwiddis, to repeat, there is a 14 month backorder on manchester tanks. I will be ready to get one when they are available and I have the money, I am going to ybe spending as much as $1000 for a rust removal service using some sort of blasting for the whole underside of my Winnie. Ilike the idea until then of in park hooked up use of a space heater that does not require venting. Doug
JaxDad wrote:Brownleaf wrote:
Long range I will get a new propane tank just exploring alternatives. Doug
This might seem like a silly question but have you had a propane shop look at the tank before it was condemned?
ASME tanks are built out of far heavier steel than most people realize. Iโve seen some really nasty-looking rusty tanks pass muster. Surface rust and some scaling is not necessarily fatal.
โFeb-26-2022 05:17 AM
jaxdad, it was the propane filler who upon my request to evaluate it, said it looked beyond just sanding and painting. thanks; I will ask about portable connectivity issues next time I am by. Doug
Doug, I hope by โpropane fillerโ you mean a qualified certified technician.
Iโve seen some really nasty looking tanks that were no problem from a safety standpoint. A little work with a wire wheel, never sand them, and a fresh coat of epoxy rust paint and continue on.
โFeb-26-2022 04:46 AM
โFeb-25-2022 05:33 PM
โFeb-25-2022 04:59 AM
โFeb-25-2022 04:02 AM
โFeb-24-2022 06:29 PM
theoldwizard1 wrote:
For heat, a mini-split heat pump is a good alternative. It does require a large inverter, battery bank and lots of solar. I would also have a portable generator.
โFeb-24-2022 03:57 PM
โFeb-24-2022 03:29 PM
โFeb-24-2022 01:45 PM
โFeb-24-2022 07:59 AM
โFeb-24-2022 07:12 AM
โFeb-24-2022 04:42 AM
