โFeb-23-2022 04:31 PM
โMar-02-2022 05:38 PM
Brownleaf wrote:
Im going to attempt to refurbish the tank and in the process will discover how deep that rust is. First I am going to have my Onan taken it out as it is not cost effective to repair it. Doug
โMar-02-2022 03:42 PM
โMar-02-2022 11:59 AM
โFeb-28-2022 10:28 PM
ajriding wrote:
No, solar panels will not compromise your roof, not any more than sitting on a chair will compromise the chair, even less in this example.
You will need a hole or entrance through the roof, so that is a compromise, but you already have a lot of holes for vents. The Fridge vent is a hole you can use if needed too.
The weight of a panel is nothing on a roof.
โFeb-28-2022 10:25 PM
Deb and Ed M wrote:
I have converted my truck camper to all-electric, but here's my caveat: we enjoy staying in campgrounds and state parks. If we boondock, it's only in temperate weather.
For heat (even when we had a motorhome; and then a 5th wheel) I use a Pelonis digital electric heater. It has a true thermostat, so we can set the temp to 72 degrees and it will keep it there; plus it has tip-over protection that turns it off immediately if it gets bumped. The added bonus: no condensation gets formed. It's dry heat.
โFeb-28-2022 07:36 PM
Brownleaf wrote:
Thanks for tip on Pelonis.20 How does a solar panel mount to the roof?
โFeb-28-2022 08:09 AM
โFeb-28-2022 06:27 AM
โFeb-28-2022 05:56 AM
โFeb-27-2022 04:26 PM
msmith1.wa wrote:
I didn't see any one suggest an extend a stay, or stay longer kit.
Stay Longer
It will allow you to connect a propane bottle to the motorhome system.
way2roll wrote:
Maybe I am missing something but this seems like it's being made overly complicated. If the existing tank is bad, and if it really takes forever to get a replacement built in, a simple device like an "extend a stay" hooked to an LP tank you can get at any grocery store will work. I am not sure what RV you have but I see LP tanks of varying sizes everywhere. Are you saying you can't find a single one to replace the existing tank? Even if the mounting hardware had to be fabricated by a welding shop, it doesn't seem that hard or expensive,
Back when Dad was full time, he had a valve system (Extend-a-Stay?) so he could put a larger tank outside, have a truck come by and fill it. He kept the onboard tanks hooked up, but turned off. (Get up, turn on tank, light furnace not good. Wake up, discover totally out even worse)
โFeb-27-2022 03:53 PM
โFeb-27-2022 10:12 AM
โFeb-27-2022 09:56 AM
โFeb-27-2022 08:59 AM
Brownleaf wrote:
I will take rv to Ford for their evaluation on the blasting. The propane establishment is busy enough for senior personnel to have reasonable opinions on tank conditions. Doug
โFeb-27-2022 03:43 AM
