Dolly towing a 2016 Toyota Avalon
DocHammer
Does anyone have experience dolly towing a 2016 Avalon? Just wondering if there is a problem with unlocking the steering column (stress on the steering system) to tow on an Acme EZ tow dolly. Cheers, Dan
6 REPLIES 6
lryrob9301
TyroneandGladys wrote:
Take the key out and try moving the steering wheel that is what feels like locked. Now try with the key in or in accessory mode and you should be able to tell the difference. I have a routine right before I get in the drivers seat of the RV I do a walk around and one of the things I check is the movement of the steering wheel of the toad.
The OP will have a hard time getting the key out since it's pushbutton start. No keys.
TyroneandGladys
Tyrone & Gladys
27' 1986 Coachmen
Campinghoss
We use the Acme dolly as well. While it is not a Avalon we tow a Highlander. As long as you turn the key to off and not the acc position and leave the key in the ignition the wheel does not lock. Our wheel does not lock until you pull the key out. As you know already it has to be front wheel drive only and not AWD.
We have well over 10 k towing miles so far with not one problem on this highlander.
Camping Hoss
2017 Open Range 3X 388RKS
MorRyde IS with disc brakes
2017 F-350 6.7 with hips 8'bed
Lucie our fur baby
Lucky 9/15/2007 - 1/30/2023
DocHammer
Thanks for the info. I will contact Acme and see if they have some advice. The local Toyota dealer doesn't really seem to know. Their position is "do anything unusual and you're asking for trouble".
C_Ref
Tyler0215 wrote:
If it's on a dolly you don't unlock the steering wheel. Strap the front wheels to the dolly and go.
The above is true for tow dollies with a pivot plate. The acme ez tow has no pivot plate, so you have to ensure the steering wheel is unlocked.
Towing the Avalon should be fine. I would call Acme for answers to your questions
2002 Shasta Cheyenne 304 class C, Ford E450
Tyler0215
