โJun-10-2013 07:08 AM
โJun-10-2013 09:13 PM
Frozen001 wrote:SteveAE wrote:
I had two of the Reese dual cam self tapping bolt mounting threads strip out. Wound up replacing all four with through bolts (5 grade) through the frame with a large washer and Nylock nut on the end. Worked great.
Steve
Was your frame a box/tube type?
โJun-10-2013 06:59 PM
โJun-10-2013 02:03 PM
SteveAE wrote:Exactly what I did when I first installed the DC setup (box frame). Snug torque only with a regular nut and LockTite on the threads. Works like a charm.
Steve
โJun-10-2013 01:49 PM
Frozen001 wrote:
I heard from Reese (Cequent):
"Yes you can use long bolts, grade 5 or 8. Only concern would be not to crush the frame. May want to make the hole bigger on the inboard side of the frame and put a tube spacer inside the frame."
Has anyone else done this on a box frame trailer?
โJun-10-2013 01:42 PM
โJun-10-2013 12:40 PM
โJun-10-2013 12:26 PM
Steve
โJun-10-2013 09:15 AM
โJun-10-2013 08:45 AM
โJun-10-2013 08:16 AM
โJun-10-2013 07:29 AM
