Dual waste tank hookup
prowler17545
My new trailer has separate drain pipes a distance apart ( one gray-one black ) unlike my old camper. Any advice on what is needed to make the two hoses connect into one so it goes into the underground dump tank ? Some type of elbow device? It's in a seasonal campsite. The dealer did not cover it in the demo.
Thanks in advance !
13 REPLIES 13
wa8yxm
Old-Biscuit wrote:
You can use a twist on 'wye' and connect using RV sewer hoses
Or you could hard plumb it and use this type of 'wye'
I have 3 tanks, Black, Gray, Wash,, And that is what I use if I hook 'em up with 3" hose.
Another trick is to replace the cap on the gray tank with one of these
Camping world Link. Termination cap with hose connector
Then you need one dual female hose connector (Hardware stores have these) and drill out the hose fitting on your elbow (And cap it if not using second hose) and a 3/4 inch GRAY hose for the gray water tank.. I use one of these on the wash water tank, the hose forms a natural "Trap" so I can leave the valve open.
NOTE: not really the recommended for a 2 tank system, but works well on a 3 tank.
If I'm using the macerator due to run length or other issues.... I have a dual inlet sewer adapter,, one is "Checked" and it gets the gray hose (Check valve in the line) If I'd have been thinking I'd likely have ran seperate pipes down but.. This way I get a really neat handle out of it too.
jeeperdude10
My class C has the same (kitchen sink grey up front-and black and shower tanks in back), I have the Sewer Solution which I use when hooked up for a week or so. I put some ball valves on both lines at the "Y" (to prevent black from going towards kitchen sink), which I close/open depending on chore at hand. I keep the stinky slinky for all stays less than a week. Works great for us!
2016 Bounder 35K
2014 Freedom Edition JEEP Unlimited
Traveling thru this great country
prowler17545
thank you all for the advice !! I got it now
ependydad
Hard plumbing the two together is the way to go, but short of that - I did the same as the folks above and used a wye:
My Camper has Two Sewer Hookups
2017 Spartan 1245 by Prime Time
2018 Ram 3500 Crew Cab DRW w/ 4.10 gears and 8' bed
FW Hitch: TrailerSaver TS3
Learn to RV- learn about RVing - Towing Planner Calculators - Family Fulltiming FB page
chiefneon
Howdy!
My new Toy Hauler also has two 3" dumps. One is for black & gray water the other gray water only. As stated I use a sewer cap with a garden hose connection and attach a garden hose to it to drain it.
"Happy Trails"
Chiefneon
ScottG
Could they be hard plumbed together?
When I went TT shopping with a buddy we saw several like you describe. A couple of them could have been replumbed so they are connected, like mine was from the factory.
fla-gypsy
Not that uncommon. Get the Y pipe problem solved.
This member is not responsible for opinions that are inaccurate due to faulty information provided by the original poster. Use them at your own discretion.
09 SuperDuty Crew Cab 6.8L/4.10(The Black Pearl)
06 Keystone Hornet 29 RLS/(The Cracker Cabana)
Maintcpo
Go to an RV Place. They sell a cap that will reduce the Grey tank down to Garden Hose size. You install this on the GREY TANK! Then route a Garden Hose to a reciever at the Dump Location which accepts a Hose end. Note: You will have to make this A FEMALE TO FEMALE hose cose. The adapter to teh sewer is pretty common and I wold be suprised if any dealer didnt hav it. Will require drilling out hole for water to drain into the adapter. I have the sewer hookup but dont use it.
Hope this helps
Dan, Ret Navy CPO
Minnie The Wife Extraordinaire
2015 Sundance 245RL
2012 GMC Sierra 2500 4X4 DSL
mowermech
I had a 1988 Suncrest Class A that had two drain lines. we lived in it during a Montana winter, using a set up similar to the one pictured above. It worked fine, no troubles.
CM1, USN (RET)
2017 Jayco TT
Daily Driver: '14 Subaru Outback
1998 Dodge QC LWB, Cummins, 5 speed, 4X2
2 Kawasaki Brute Force 750 ATVs.
Pride Raptor 3 wheeled off-road capable mobility scooter
"When seconds count, help is only minutes away!"
Old-Biscuit
jdog wrote:
Strange set-up! Not normal!
What's 'normal' :B:B
Lots of rvs have two separate drain lines.
Waste tank forward of axles and waste tank rearward of axles will use separate drain lines.
That would be 'normal' for that set-up
jdog
mdamerell
Made this up with Rhino parts. Shortened the hose at the drain line to keep the "y" where I wanted it.
2012 Sundance 3100RB w/Reese Goose Box
2004 Ford F350 6.0 L PSD, CC, DRW, long bed, B&W drop ball hitch, Firestone Ride-rite air bags.
Old-Biscuit
