โSep-01-2014 07:44 AM
โSep-03-2014 07:40 AM
โSep-03-2014 05:20 AM
โSep-02-2014 07:55 PM
โSep-02-2014 07:45 PM
โSep-02-2014 06:18 PM
โSep-02-2014 06:08 PM
Poppy & Nana wrote:My wife found a dishtowel with a nice scene on it almost the same size as the window in the door. Did the same thing as Poppy & Nana to our bedroom door window.
Trim a piece of vinyl and add Velcro to strategic places - remove when not needed...
Reese Dual Cam Straight Line HP Sway Control
โSep-01-2014 12:10 PM
โSep-01-2014 11:39 AM
stevekk wrote:
Any suggestions on how I add privacy.... like a
curtain, shades, blinds, louvers, etc.
My MH has a curtain with 3 snaps that hangs down from the inside wall, in front of the entry door window.
And is very awkward going in and out of door, since this curtain is always hanging in front of me.
Does anybody make a entry door window with blinds between 2 panes of glass?
Electric operated?
Any and all other ideas appreciated. Thanks..
โSep-01-2014 11:22 AM
โSep-01-2014 11:01 AM
โSep-01-2014 10:06 AM
bukhrn wrote:restlesswind wrote:X-2, ours came with a frosted window also.
You could change the glass to frosted.Our 5th wheel came with it in the door window.
We also use the foil bubble wrap attached with a couple of short strips of white velcro
to cut the light,when needed.
โSep-01-2014 09:49 AM
โSep-01-2014 09:41 AM
pfidahospud wrote:
One thing that I've noticed, though, is that the adhesive on the Velcro fails after being in high heat conditions when facing the sun. Maybe there is a high heat Velcro option?
โSep-01-2014 08:46 AM
