โApr-14-2015 12:21 PM
โApr-14-2015 07:06 PM
Halmfamily wrote:LarryJM wrote:Halmfamily wrote:
Thanks everyone, I'll stop by Lowes and get some acetone. Happy Camping
One extremely important step IMO is to make sure when you clean an area you make sure your rag (use a dark colored one) is not still removing a lot of "white residue" which is the sacrificial flaking of the EDPM rubber. If there is too much of this residue left then the Eternabond tape will "lift" down the road since the residue will interfere with the microsealant holding.
Larry
This roof is only 9 months or so old and is tan not white. Is residue still going to be an issue?
โApr-14-2015 07:02 PM
Larry
โApr-14-2015 06:45 PM
โApr-14-2015 06:33 PM
โApr-14-2015 03:52 PM
โApr-14-2015 03:26 PM
โApr-14-2015 03:14 PM
โApr-14-2015 03:10 PM
WyoTraveler wrote:
Acetone is like killing ants with a hammer. Most use mineral spirits. You need it clean you don't need to remove paint or melt rubber.
โApr-14-2015 03:01 PM
โApr-14-2015 02:57 PM
โApr-14-2015 02:14 PM
โApr-14-2015 01:42 PM
Halmfamily wrote:
Do I need to use the Eternabond Primer prior to using the tape? Can I just thoroughly clean the area with alcohol and lay down the tape, roof is only 9 months old. I need to cover the seam on the front where the cap meets the roof, apparently someone had a bad day sealing this area. Any other tips would be appreciated also .
โApr-14-2015 12:46 PM
โApr-14-2015 12:35 PM
