โMar-29-2021 12:04 PM
โApr-07-2021 03:50 AM
valhalla360 wrote:JRscooby wrote:
Why does a compressor fridge require a hole in the roof?
It doesn't...that's a nice advantage. But some people seem to think, leaks don't tend to concentrate around holes in the roof membrane.
Obviously, it's not a 100% solution to leaks but it's a start. Honestly, most of the holes in the roof could be eliminated.
- Properly done sewer vents in the side wall would be less leak prone.
- With cheap low wattage LED, the need for roof hatches to let in light are not as important.
If you eliminate all the roof penetrations, the standard rubber roofs will hold up much better with less maintenance. Even better metal or fiberglass roofs become much cheaper options and are even less leak prone.
Slapping another layer of dicor sounds good but reality is most RVs go to the junk yard due to leaks.
โApr-06-2021 06:21 PM
โApr-05-2021 07:23 PM
2oldman wrote:
OP, let us know what you decide on.
โApr-05-2021 09:01 AM
โApr-02-2021 02:23 PM
GDS-3950BH wrote:I put 48 holes in my roof to mount my solar panels. Just don't be stingy with the Dicor!
some think you have a huge benefit by having 1 less hole in a roof. Whatever LOL.
โApr-02-2021 01:24 PM
โApr-02-2021 08:32 AM
โApr-02-2021 05:17 AM
โApr-02-2021 04:26 AM
GDS-3950BH wrote:valhalla360 wrote:GDS-3950BH wrote:
no gas service is needed, and no wall or roof venting is required.
This is something I consider a big positive.
Leaks are usually what kills an RV and leaks typically come from holes in the roof.
An RV with an electric fridge still has "holes in the roof". So you might have 1 less hole in the roof which matters little if you have two vents,AC,skylight,a plumbing vent or two, and a TV antenna. I don't know how having 7 holes in the roof is a big positve over 8 holes in the roof, but whatever floats your boat I guess.
โApr-02-2021 03:32 AM
โApr-01-2021 08:06 AM
โMar-31-2021 11:13 AM
โMar-31-2021 10:34 AM
AllegroD wrote:Seriously. You have to have a bit of education to know when a salesman is blowing smoke.
Who lets their lead acid 12v battery drain to 9.48v?
โMar-31-2021 10:24 AM
