Fire Starters from RV Travel tips question
Mountain_Mama
"Fire starter tip
Need fire starters? Reader S. Fox sends us a suggestion from The Old Farmer's Almanac: Start with dried pine cones. Melt old candle stubs in a double-boiler. Dip the pine cones into the hot wax. Let dry, perhaps on a cookie sheet lined with aluminum foil. Store when dry. The wax helps the pine cones burn long enough to help get your fire going. For special effects, soak the dried pine cones for 24 hours in a solution of 1 pound Epsom salts to 1 gallon water. The treated dried cones produce a myriad of colors in the campfire.'
I just read the above on the daily RV Tips from rvtravel.com. Has anyone tried soaking the pine cones in the epsom salt & water? If so, is it best to soak them before dipping in melted wax after they've dried, or after, or does it matter? :h TIA!
2003 Holiday Rambler Alumascape 34RLT
19 REPLIES 19
Dakzuki
Paper, dry kindling, and apply flame. Works every time No need to carry smelly flammable stuff. Everything can be carried in paper bags or a small cardboard box which also become part of the equation.
I also carry an ax, hatchet, and buck saw. I forage for firewood where it's legal.
2011 Itasca Navion 24J
2000 Chev Tracker Toad
MitchF150
We tried that dryer lint thing and it technically burned, but burning dryer lint does not smell very good... ๐Ÿ˜‰ We just lit the TP roll stuffed with it. Did not really see how it would catch the wood on fire?? Not much flame at all..
For me, I just apply a liberal amount of charcoal lighter fluid on the dry wood and ignite and I have a fire going pretty easy....
Mitch
rvjames
RaenMark wrote:
We save dryer lint, wad it up into the paper egg cartons then pour melted canning wax until the lint is saturated. Let it dry then store in a dry container. I use an old ammo can, it's all metal and the lid seals well. No paper egg cartons in your area, use old TP or paper towel rolls, stuff them full then cut with a bread knife into 1-1 1/2" sections. Even with the pot I bought for melting the wax, I've got over 3 years of fire starters for less than $10.
This is a neat idea. I knew there had to be a way to use dryer lint constructively. I was curious so I did a google search. Some pictures of dryer lint fire starters here
4kyyote
hand sanitizer and cotton balls.
lamopar
I always have propane bottle with the auto-light torch with us. Lights small wood or paper very quickly and if I make a teepee with the small wood and put a piece of paper in the middle it takes right off. If it is raining, use 4 large pieces of wood as the 4 corners and place a large piece of bark across. Build your teepee under the bark and you get a nice fire again. You can also use the bark as a wind break to get a fire started with matches if you forget your torch. Dry moss works great as a starter also. If you are desperate carry some pool cleaner, calcium hyperchloride powder, and DOT 3 brake fluid. Put your wood down, put the powder on the wood and pour some brake fluid on and stand back. You will have a nice fire pretty quick. Best part is you may need the brake fluid for your rig and pool cleaner is not real hazardous to carry in a small zip lock bag. Just some stuff I have done.
mosseater
I try to use what I have on board or in my bug out kit. Cotton balls (or lint in the afforementioned post) massaged with Vasoline that I keep on board for my spring bars. Saturate the cotton ball, then spread it apart with your fingers and light. Burns pretty well to get a fire started. Steel wool burns like crazy, too. Be careful what you store in enclosed containers. Oily rags or wood chips might spontaineously ignite.
"It`s not important that you know all the answers, it`s only important to know where to get all the answers" Arone Kleamyck
"...An unarmed man can only flee from evil, and evil is not overcome by fleeing from it." Col. Jeff Cooper
Sunset Creek 298 BH
RaenMark
Rae & Mark
Bountiful, UT
2005 Alfa See Ya 40
Finally found a rig I can stand up in!
jeepfreak
We use Yankee Candle fire starters. They are about the size of the average cupcake and are a wax candle that burns long enough for about anything to catch. Plus they really smell nice when you open up the compartment there stored in.
2007 Allegro 34wa Workhorse 8.1, Allison 6-speed. Bow Tie powered 79 CJ-7 Toad or 2014 Jeep Unlimited Rubicon Toad
prujak
Get a five gallon bucket with a lid. Get some dried wood chips and fill the bucket. You can use the chips from a wood chipper. Find the place where they dump them and get the dry ones. Pour kerosene over them put the lid on and shake it up. Don't need allot. Dump a couple handfuls into the fire ring and place firewood over it. Light. Great fire starter. You can also use diesel or heating oil.
Paul & Patty
Two Grandchildren No pets
2011 Ford F250 Super Duty Lariat
2014 Rockwood Signature Ultra Lite 8329SS
_40Fan
Just fire up your Norcold refrigerator. That will start an RV fire that you can be proud of. Or did I read the heading wrong?
Worst part is I am about to buy a TT with a Norcold. Better make sure I keep a fresh pack of hot dogs next to the bed.
2013 Arctic Fox 22GQ
2011 Ram 2500 CC LB CTD G56 3.42 Mineral Gray
deleted-2
Been using inexpensive citronella oil poured on rolled newspaper whoom!
(not really a whoom it just stays burning long enough to get dry wood going good)
Diesel fuel works too... @ 4 bucks a gallon.
:C
CincyGus
I have used the corn chip method once to impress someone and it worked pretty well. They say it's the cooking oil that soaked in the chips. After I tried it, I understood why they make you fat, lol.
I generally cheat and put about 4 or 5 charcoal briquettes down, light them then start building my teepee of logs around it. It takes less fanning and I get less smoke in the eyes.
2015 GMC 2500 Denali Crewcab 4x4
2019 Forest River Wolfpack 23pack15
Hope your travels are safe and the friendships made camping are lasting.
ctpres
Try FRITOS corn chips as fire starter. Light ONE chip and you will be amazed at intensity of flame. I pretty much stopped eating Fritos after I burned a couple.
A "Retired" Mind is a Terrible Thing to Waste
Chuck USNR, USAF & USCGA and Suzie
Challenger Owners Club
2015 Thor Challenger 37KT
2014 Ford Fiesta
2011 Sea Eagle 385 FT kayak
2009 Polaris RZR
2014 Zenetto Stealth road bike
sljkansas
I get enough junk mail I don't need to buy any fire starters, but thanks for the idea. We don't see many pine cones here in Eastern Kansas. After thinking about it it's most all of Kansas.
Steve & Linda
Son married (1 DIL, 3 granddaughters 1 grandson)
Daughter Married.
Miami Co. Kansas
2004 F350 CC dually 8ft bed 6.0 PSD
2009 Bighorn 3670RL
B&W under bed hitch with 18k companion hitch
