โJan-17-2014 06:13 PM
โJan-20-2014 08:58 AM
โJan-19-2014 05:33 PM
afrescop wrote:Bulb and socket wiring kit. http://www.amazon.com/gp/aw/d/B003VAUQ2I
If the battery is disconnected how do you get the brake, tail and turn signal lights to work?
โJan-19-2014 01:34 PM
ontken wrote:
It looks like I will be buying a battery disconnect, the steering whell does lock and the key must be turned to stop it from locking. I will let you know how it works out. Thanks for all the suggestions.
โJan-19-2014 01:11 PM
โJan-18-2014 05:22 PM
tatest wrote:
Check to see what actually makes the wheel lock, if it does at all.
On my manual transmission Fit, the lock is not activated until the key is pulled out, so I can leave the key in the "off" position. Same for my manual transmission truck.
It is more towable automatics that have the key problem, i.e. switch must be turned to an "on" position to get the selector out of Park.
โJan-18-2014 04:21 PM
โJan-18-2014 03:34 PM
โJan-18-2014 02:15 PM
โJan-18-2014 12:38 PM
โJan-18-2014 11:31 AM
โJan-18-2014 10:24 AM
โJan-18-2014 09:21 AM
โJan-18-2014 04:46 AM
โJan-17-2014 06:32 PM
