Ford Edge vs Chev. Equinox
Tripalot
We are trying to decide between the 2016 Ford Edge and Chev. Equinox as a dingy (4 wheels down) to tow behind our Class B+. Both are capable of being towed as confirmed in the owners manual.
Can anyone comment on the Ford 2.7 L Eco Boost 6 cylinder as compared to the Chev. 2.4L 4 cylinder or 3.6L 6 cylinderl
Both vehicles weigh about the same and have the same towing requirements and speed limitations.
Would be interested in hearing of any experience you may have with either vehicle or engine size.
2014 Triple E Regency GT24MB (Murphy Bed) with all the good stuff
towing a 2016 Jeep Cherokee TrailHawk
Berkley, the amazing camping cat missed dearly (1996-2012)
10 REPLIES 10
chevylover1965
Dick
This came from the Ford owners manual.
You can tow your 2.7L EcoBoost or 3.5L (6F50 or 6F55) equipped vehicle with all four wheels on the ground.
If you tow your vehicle with all four wheels on the ground:
Tow only in the forward direction.
Release the parking brake.
Vehicles with Keyless Start (If Equipped)
Start the vehicle by pressing the brake pedal, and then pressing the keyless start button until the vehicle starts.
Press the brake pedal and shift the gearshift into neutral (N).
Turn the vehicle off by pressing the keyless start button once.
Disconnect the negative (black) cable from the battery. You need the door key to lock and unlock doors when the battery cable is disconnected. See Changing the 12V Battery.
Note: The anti-theft system does not work until you reconnect the battery cable.
Start the engine within 15 minutes of reconnecting the battery cable.
Vehicles with an Ignition Key (If Equipped)
Start the vehicle by pressing the brake pedal, and then turning the ignition key until the vehicle starts.
Press the brake pedal and shift the transmission into neutral (N).
Turn the vehicle off by turning the ignition key past the accessory position. The key position is between the accessory and off positions. See Ignition Switch.
Disconnect the negative (black) cable from the battery. See Changing the 12V Battery.
2015 Tiffin Allegro 36 LA
2006 Tiffin Phaeton 40 QDH (Sold)
2016 Chev Equinox LTZ AWD V6
Roadmaster Falcon All Terrain tow bar/US Gear
FBINA 144
Tripalot
We drove the 2016 2.7L 6 cylinder Edge. It was a very nice riding vehicle but the price for us worked out to $10,000 more than the Equinox. The Ford was definitely quieter and more powerful than the Equinox, Installing the Invisibrake in the Equinox could be a problem - that needs to be checked into.
Finding out what our trade in vehicle is worth was a bit of a shocker. Lots to think about before signing on the dotted line!
dicknellen
This is from the 2016 Ford towing guide for 4 down towing
Edge 3.5L/2.7L EcoBoostยฎ (FWD/AWD) Auto Transmission Yes (3)(4)(5)
(3) All-wheel-drive/Intelligent 4WD vehicles cannot be towed on a dolly.
(4) Maximum speed with automatic transmission is 65 mph.
(5) Start the engine and allow it to run for five (5) minutes at the beginning of each day and every six (6) hours thereafter.
Nothing about battery or only V6. Dick
YC_1
I have a 2012 Rear wheel drive Edge Limited. V6. The battery does not need to be disconnected.
H/R Endeavor 2008
Ford F150 toad >Full Timers
Certified Senior Electronic Technician, Telecommunications Engineer, Telecommunications repair Service Center Owner, Original owner HR 2008
chevylover1965
We looked at both and chose the Equinox LTZ V6. I didn't like having to disconnect the battery when it's towed,and the Equinox has more BHP. Good luck.
FBINA 144
K_Charles
down home wrote:
You can't flat tow the Edge with the Eco boost engine. It has to be the v6.
Ford says you can for 2016
SPRING_STREET
I have a 2012 Ford Edge FWD with the Eco boost. Did they change it on the new models ??
2011 MOUNTAIN AIRE 4344, FMCA F334596, Cummins Power Play,Good Sams and KOA member..TOAD 2017 Ford Edge Titanium with a 6 cylinder Engine, License plate "TOWED" > RoadMaster Night Hawk Tow Bar and Base Plates. ๐Ÿ˜‰
down_home
YC_1
Just be absolutely sure the model Edge you might buy is towable. Not all Edges are. We have been towing our for three years. Very easy to tow. I did install a charge line. The vehicle does not get the best mileage but has lots of power.
H/R Endeavor 2008
Heisenberg
The Equinox with the 2.4 is an excellent daily driver and toad. I have a 2012 FWD.
2013 Winnebago Sightseer
2017 Colorado
