โNov-23-2022 02:49 AM
โNov-24-2022 01:18 PM
โNov-24-2022 07:31 AM
Pbutler97 wrote:
It's an income generator for the selling dealer's service department designed to keep their income coming forever. You have to take it in to the selling dealer for a yearly inspection that will set you back a couple hundred bucks or more to keep it in effect. Most will find something that needs addressed.
ON AN ANNUAL BASIS, YOU MUST PERFORM THE FOLLOWING MAINTENANCE
* Inspect roof and seal where necessary
* Inspect axles and hub, lube where necessary.
* Inspect furnace โ clean blower and combustion chamber, control compartment, (remove any dust, lint, and obstructions) as necessary, test for gas line leaks.
* Inspect hot water heater โ flush holding tank, manually operate pressure temperature relief valve, and clean burner tube (as outlined by the manufacturer), as necessary.
None of the required maintenance listed above is covered by the warranty.
Sir, your entire roof needs resealed, $1100.00, your bearings need packed $800.00, your gas lines all need adjusted $500.00, and we have blow lint out of the furnace valvulator, $200.00.
It's a shell game you can't win.
โNov-24-2022 05:30 AM
โNov-24-2022 03:04 AM
โNov-23-2022 11:09 PM
โNov-23-2022 03:02 PM
โNov-23-2022 01:16 PM
โNov-23-2022 04:36 AM
โNov-23-2022 03:12 AM
