โJul-15-2017 07:06 AM
โJul-15-2017 01:04 PM
Bob Vaughn wrote:
My frame is by Lippert so I assume that the mechanism is made by them also
โJul-15-2017 12:37 PM
โJul-15-2017 10:15 AM
โJul-15-2017 07:40 AM
โJul-15-2017 07:29 AM
โJul-15-2017 07:20 AM
fj12ryder wrote:
I assume that you've checked to make sure the cross shaft is still connected to the motor shaft. Is there any noise, like a clicking or snapping? If no noise at all it could be the bevel gear has sheared its drive pin. And of course then you'll have to figure out why. Haven't these legs given you issues in the past, or am I confusing you with someone else.
If you can get the inner leg up enough, you should be able to put the jack under the pad and use it to lift the trailer along with the other leg. That should be enough to get you back on the truck. Then just find level sites and don't unhook the truck. ๐
โJul-15-2017 07:15 AM
