mark_be wrote:
ktmrfs wrote:
I have a light than flashes indicating tank switchover in my trailer.
Sounds interesting! How dow did you do that?
Edit: found this item.
Yup, that's it. But WAIT, not so easy anymore.
FIRST you have to have a marshall 254 regulator. THAT is the tough part, they are no longer made and it is no longer readily available. A few places have some left but they want mucho $$$$ for them.
But if you have one, Marshall has a "changeover" indicator still available that works with the 254 regulator. you remove the top cap on the 254 regulator, pop on the changeover indicator which has a switch and lever in it. Then you run the included wire to someplace inside the trailer to the included flashing module, install 2 AA batteries in the module.
When the regulator changes over, the regulator changeover will close the switch on the top of the regulator and the light on the inside unit will start flashing.
Very handy!!!
Now it may be possible to adapt the changeover indicator to other regulators, haven't tried that.
2011 Keystone Outback 295RE
