Feb-15-2022 10:48 AM
Mar-19-2022 10:27 AM
Mar-19-2022 10:22 AM
valhalla360 wrote:BackOfThePack wrote:
When diesel costs $4.25/gl and gasoline runs $2.80/gl the fuel economy is the same.
16-mpg diesel and 10.5-mpg gasser.
1). Figure miles owned in advance. Add diesel premium to needed differential (and insurance plus maintenance, etc).
Diesel equivalent hasn’t been cheaper since 2007.
There are some wacky numbers on this thread.
- 2mpg...maybe if you are climbing an 8% grade and try to keep up at 75mph...but over 50-100miles, it would be almost unheard of and in mountains, there is typically a downhill to go with every uphill.
- Diesel typically get's 20-40% better MPG (and 40% is unuusal). 52% improvement strains credibility.
For general planning purposes, figure somewhere on the order of 7-12mpg.
Biggest issue is driving style.
- Slow down a bit often will generate significant MPG improvements.
- If in hilly, let gravity speed you up on the downhill and then let a little speed bleed off on the uphill (assuming you aren't in a congested area disrupting traffic).
- Doesn't work for weekenders (or if you have a weeks vacation) but we've actually changed travel days based on wind projections. Going from a 30mph headwind to a 10mph tailwind has a pretty massive impact. At 60mph, the engine feels 90mph vs 50mph loads, since the bulk of the power is fighting wind resistance.
Mar-19-2022 10:17 AM
And yet where you live the 2 fuels are about the same price. And generally are within about 10% of each other everywhere, not the 50% difference to embellish your point.
Mar-15-2022 12:07 AM
Mar-14-2022 12:52 PM
Mar-14-2022 11:21 AM
Mar-14-2022 11:05 AM
Mar-02-2022 04:40 AM
Feb-25-2022 02:40 PM
Feb-17-2022 01:02 PM
Feb-17-2022 12:44 PM
Feb-17-2022 09:28 AM
Grit dog wrote:
OP, great question, but at the end of the responses, you won’t have any succinct info anyways. There are just too many variables, not the least of which is the owners “perception” of their mileage.
Factor in everything else to make your decision, imo. Diesel will be about what is expected at 20-30% better mileage if comparing apples to apples.
Feb-16-2022 09:26 AM
Jayco23FB wrote:Sjm9911 wrote:
Im going to go here again, you can look up previous posts. 9 to 14 towing depending on speed and terrain. Around 13 at say 60 mph, 65 to 75 will be 10 to 12 or a bit more. I usally will go faster. I think I got 13 avrage to disney from nj at like 65 mph. 13 to 16 not towing on the same principle. I get 15 ish at 65-70. And 14 to 13 at say 80. I have 26000 miles on my 2020 2500 double cab? With reguler bed lt 4x4. Half of that or more towing. TT is about the same weight. I do load up the bed with lots of junk and use the bed outlet while towing. Pros, bigger gas tank, less stops. Trips that I had to stop 3 times for fule with the 1500 can be made on one fill up. This is because larger fule capacity and a little better fuel economy on the newer truck. Not much difference in towing vs not towing with a 5500 lb TT. Maybe 1 to 2 mpg less.
Duramax?
Feb-16-2022 08:13 AM
