Help me find these switches
ScottG
I would like to add a few circuits to our TT and need to buy a couple of these exact (color, etc) switches. I'd rather get them on-line than from Northwood.
Anybody know where I can get them?
Thanks,
Scott
13 REPLIES 13
Dave_H_M
bucky wrote:
Rattle can the white ones.
Yep, that Krylon for plastic would work for me
jplante4
We have them in the store. If you run out of luck PM me with the part numbers.
Switch
If this isn't the right one, poke around the catalog under 12 Volt Switches and dimmers and send me the part number.
Jerry & Jeanne
1996 Safari Sahara 3530 - 'White Tiger'
CAT 3126/Allison 6 speed/Magnum Chassis
2014 Equinox AWD / Blue Ox
bucky
Puma 30RKSS
path1
Jr products because of postings or ???
Say that because rv designer has a couple in book. Book from 2014 era.
Not ordering from NW via sumner. Don't blame you. Last time for me was 3 weeks.
2003 Majestic 23P... Northwest travel machine
2013 Arctic Fox 25W... Wife "doll house" for longer snowbird trips
2001 "The Mighty Dodge"... tow vehicle for "doll house"
ScottG
Thanks everyone,
DE Bishop, those numbers are for some smaller switches and some of the newer style "contoured" switches.
Path1, Good suggestion. I'll open one of them up tomorrow and see if I can find any P/N's.
At this point all I know for sure is that they are Jr Products parts but at least that's something! The switches themselves are easy to find, it's the surface mount housings and baseplates that are elusive.
Thanks again for your efforts.
Scott
D_E_Bishop
Click For Full-Size Image.
Try googleing these numbers
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
2002 Winnebago Adventurer 32V
2009 GMC Canyon
Roadmaster 5000
BrakeBuddy Classic II
path1
Any luck with taking cover off and look inside for Corp name?
I see Jr products number 13525 (which is NTP 19-2796)
Also says "used with face plate nos. 2841-5 through 13475"
So not sure what you have.
I've got about every part in our rv id's but not our switches...thanks for posting and something I need to check out.
ScottG
mobeewan wrote:
Tweety's has the base in white. They also have switches. You'll have to look through their website to see if they have black.
Other sources.
Thanks, They do indeed have white but not the black. Odd that I can find the white everywhere but as soon as you go to Jr. Products in black, I get the other style.
I may just have to convert over to the newer(?) style.
Not digging the black switches. Some of them I can hardly see against the dark background in parts of our trailer.
mobeewan
Other sources.
GordonThree
Looks like a standard black rocker switch. Auto parts store, Best buy, if you're lucky, Fry's.
Otherwise mouser.com or digikey.com
2013 KZ Sportsmen Classic 200, 20 ft TT
2020 RAM 1500, 5.7 4x4, 8 speed
ScottG
ependydad wrote:
Did you happen to have a picture to go with this?
Oh brother! I knew I was forgetting something.
ependydad
2017 Spartan 1245 by Prime Time
2018 Ram 3500 Crew Cab DRW w/ 4.10 gears and 8' bed
FW Hitch: TrailerSaver TS3
Learn to RV- learn about RVing - Towing Planner Calculators - Family Fulltiming FB page
OldGunbunny
Try Newark.com
